98 wheel sensors
ALL TPMSs will fit all OEM wheels. Now, aftermarket is a different issue, and varies.
You can always strap and epoxy them into any wheels. You have to mark location, so you can use a magnet to train.
2KHardtop,
Your owner's manual has the reset procedure or you can do a search here on the forums under Tire Pressure System.
You'll be amazed at what you find.
hth,
Jim
hth,
Jim
Received 1,680 Likes
