Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2008, 05:18 PM   #1
Kurtomac
CF Senior Member
Default Mobil 1 or Royal Purple....Mobil 1 Vs. Wix
ok just bought my usual Mobil 1 at autozone....cant seem to find wix filters around here....went to advanced to see if they had wix filters.....negative so i ended up grabbing one of those 10 dollar extended performance filter Mobil 1 sells....anything has to be better than AC delco...i mean **** it has to filter better it weighs twice as much as the ac delco...how does the mobil1 filter compare to the wix filters.....
On another note while i was at Advanced...I noticed they now sell Royal Purple synthetic motor oil... its not even a dollar more a quart than M1....Is RP that much better than M1? thought bout taking my M1 back and giving the RP a try with my new M1 filter....Your thoughts...................
Kurtomac is offline   Reply With Quote
Old 07-18-2008, 05:49 PM   #2
verano29
CF Senior Member
Napa Gold = Wix
Royal Purple is superior to M1
verano29 is offline   Reply With Quote
Old 07-18-2008, 06:15 PM   #3
Corvette Don
CF Senior Member
Corvette Don's Avatar
Yea napa sells them but they overprice them, $7 and some change for a damn filter. Do what I did and buy a case of 12 WIX filters from ebay for $55 shipped. Also I picked up a case of RP for $80 shipped. You will save a few bucks doing it that way
__________________
2000 Z51 Coupe - SOLD
1997 NBM Coupe
Corvette Don is offline   Reply With Quote
Old 07-18-2008, 06:21 PM   #4
Oldvetter
CF Senior Member
Oldvetter's Avatar
WIX or NAPA GOLD will flow better than Mobil 1 oil filters. I got 10-15 psi more cold oil flow (since the C5 oil pressure sensor is AFTER the filter, more psi = more flow).
Standard DELCO Oil filters are NOT bad. The premium DELCO UPF-44 filter as do a Mobil 1 (too restrictive for me).
I think Mobil 1 is a great oil. I have heard some bad things from racers about Royal Purple, although I am sure it is a good oil for a street car.
Oldvetter is offline   Reply With Quote
Old 07-18-2008, 06:48 PM   #5
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
If you use Mobil 1 and a WIX filter, the engine will last longer than you want to keep your car. Heavier and more restrictive are not necessarily better when it comes to filters.
TEXHAWK0 is offline   Reply With Quote
Old 07-18-2008, 07:09 PM   #6
Corvette Don
CF Senior Member
I thought more pressure meant more restrictive? You get pressure from resistance...
Old 07-18-2008, 07:39 PM   #7
Oldvetter
CF Senior Member
Oldvetter's Avatar
Quote:
If you were measuring the pressure BEFORE the oil filter, you would be right. BUT more pressure AFTER the oil filter means a LESS RESTRICTIVE oil filter and MORE OIL FLOW. The pressure drop from before to after the oil filter is what shows the restriction of an oil filter.
The premium filters (Mobil 1 and DELCO UPF-44) actually filter "too good" at the expense of oil flow.
Old 07-18-2008, 08:31 PM   #8
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14
Quicksilver Vert 01's Avatar
It's the oil pressure AFTER the filter that matters.
Quicksilver Vert 01 is offline   Reply With Quote
Old 07-18-2008, 09:05 PM   #9
jstrime
CF Member
jstrime's Avatar
Default WIX Filter
You can also buy the WIX filters at O'Reilly's !!!
jstrime is offline   Reply With Quote
Old 07-18-2008, 09:05 PM   #10
Corvette Don
CF Senior Member
Quote:
Ahh, you guys are right, I forgot the sensor is after the filter
__________________
1997 NBM Coupe
Old 07-18-2008, 09:44 PM   #11
Kurtomac
CF Senior Member
Quote:
Originally Posted by verano29 View Post
Napa Gold = Wix
yes i know this...there is neither a wix seller or napa store in the area
Old 07-18-2008, 10:13 PM   #12
AlohaC5
Get ready to unleash Hell
St. Jude Donor '08-'09-'12
Support Corvetteforum!
AlohaC5's Avatar
Send a message via MSN to AlohaC5
Napa Gold = Wix
AlohaC5 is offline   Reply With Quote
Old 07-18-2008, 11:59 PM   #13
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
I use the K & N oil filter.
jrose7004 is online now   Reply With Quote
Old 07-19-2008, 12:14 AM   #14
rws.1
CF Senior Member
rws.1's Avatar
I have never been able to justify the premium for boutique oils...
AS long it is a brand you know and trust and meets the GM4718M spec....
rws.1 is offline   Reply With Quote
Old 07-19-2008, 08:51 AM   #15
Kurtomac
CF Senior Member
so should i take the M1 back and get the RP? So whats the conclusion...should I take back the M1 filter and go with a delco or try and find a place that sells wix?
Old 07-19-2008, 11:00 AM   #16
whylee
CF Senior Member
whylee's Avatar
You will be fine using the Mobil oil and filters, I have used them for years.
Now if it was a fram filter, I would say throw it in the garbage can. Mobil, K&N, Wix, they are all good.
I like both RP and Mobil 1. I happen to use Mobil 1 in my engines and Royal Purple in my tranny's and diff's. just because its not as easy to always find the Royal Purple when its time to change the engine oil.
But it does look cool having purple oil
whylee is offline   Reply With Quote
Old 07-19-2008, 01:27 PM   #17
JC in XTC5
CF Senior Member
JC in XTC5's Avatar
In the grand scheme of things, your M1 oil is fine, your M1 filter is fine. If you're not racing your car there is virtually no difference.
JC in XTC5 is offline   Reply With Quote
Old 07-19-2008, 03:02 PM   #18
Corvette Don
CF Senior Member
Quote:
They did a test between a K&N and a WIX and when they took them apart the had pretty much the same filter media and anti drain back valve. I would not be surprised if K&N has WIX make their filters
Old 07-19-2008, 03:32 PM   #19
Camjamsdad
CF Senior Member
St. Jude Donor '13
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicycle.
I think there's two different RP oils. The fear is they boost horsepower by sacrificing the stickiness oil needs to stay on your parts. Less resistance and drag on the moving parts equals horsepower. But I'd rather have oil that clings well to my parts so I use Castrol Syntec. It doesn't matter which synthetic you use if it gets changed out regularly, that's the key. I do use RP in the rear end, and tranny, and highly recommend it.
Camjamsdad is offline   Reply With Quote
Old 07-19-2008, 06:53 PM   #20
Lafd4me
CF Senior Member
Lafd4me's Avatar
There was another thread on the RP -vs- Mobile 1
It might help.
http://forums.corvetteforum.com/show....php?t=2070913
Lafd4me is offline   Reply With Quote
Reload this Page Mobil 1 or Royal Purple....Mobil 1 Vs. Wix
Tags
c4, c6, carquest, corvette, filter, mobil, mobil1, napa, oil, premium, purple, royal, sell, witch, wix
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
