HVAC readout temps are dim?
Old 08-03-2008, 06:31 PM
David426
David426's Avatar
Default HVAC readout temps are dim?
I've read several others post that the inside temp readouts are dim and sometimes unreadable in daylight.. Whats the fix for this?
Old 08-03-2008, 06:38 PM
byronhunter
byronhunter's Avatar
Default dim display
http://forums.corvetteforum.com/show...t=hvac+display
Old 08-03-2008, 06:48 PM
MagRedConv
Support Corvetteforum!
MagRedConv's Avatar
Check out the Ultimate DIY sticky
Old 08-03-2008, 07:49 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
I've have spares ready if in CT
Old 08-03-2008, 08:04 PM
C5Pat
C5Pat's Avatar
Sent PM
Old 08-03-2008, 09:07 PM
itzza427
itzza427's Avatar
Just a tip,,the fix is pretty easy and it works!! The tip is get a small traditional soldering iron.I got one of the battery powered COLD HEAT irons(bought it a t Wally World,,and if I had the receipt I'd take it back!! its awkward to use and not very effective. Could barely get it to melt the original solder,and wasn't able to add any additional solder.Thank God it worked by just remelting the original solder.After doing it once though,in needed it will not be a big deal as after the first time it will go a lot easier if needed again!!
To HVAC readout temps are dim?
Quick Reply: HVAC readout temps are dim?
