My Corsa Daytona Exhaust sounds like a farm truck.....
Like I said... Sounds like a farm truck when I let off the gas. Kinda like the old glasspacks. Anyone else have this issue? I thought I might have an exhaust leak up front sucking in cold air when I let off the gas, but I have not found one.
Yep when the RPM drops into the lower range it will do a little crackle popping,,in particular if you have the stock H pipe.I kinda like it in my Corsa Touring!! An X pipe will make a very noticeable reduction if you don't like it. The stock H pipe has only a tiny 1/2" hole in the side wall of the main pipe at the crossover section,thus virtually no flow balancing effect!!
I have a Bassani X pipe on the car now. Not sure if any other mods were done, these were on the car when I bought it. It really sound pretty loud to me, not sure if maybe the previous owner might have gutted the cats..
I have the Daytona Touring exhaust from Corsa. It has never sounded like a "Farm Truck." Do you mean its loud or the exhaust note is unpleasant? It is a little louder when cold but it is never obnoxious and it screams at WOT. The vid is a cold start - Kooks LTs, Hi-flow cats and X-pipe mid section.
I did the catbacks first on a stock mid section and manifolds. Then I added headers and an x-pipe with the stock cats. Finally put in hi-flow cats. Each change modified the sound a little bit but it has never been bad.
Corsas have a lifetime warranty to the original buyer. If you bought the catbacks new I would call Corsa for warranty support if you think you have a problem.
Unfortunately they were on the car when I bought it, so now warranty. That sux because one of the tips has formed a crack in the back on the bottom. The sound is fine under acceleration, not too loud, sounds nice. I just have a lot of "popping" when I let off the accelerator, like glass packs. I need to pull off the cats and see if the previous owner may have gutted the cats, I have heard that can make for a decel pop.
I've got the Corsa Pace edition with those "Daytona" tips, and they kind of act like a megaphone, and magnify sound pulses. Mine is LG LTs, HF cats, and 3" to the catback, and though it's very loud, the decel popping is minimal. Don't know why it would be so bad on a mostly stock system with an X.
