Intake/throttle body coupler
If you had the option would you use a hump hose or a straight hose coupler between a CAI and the throttle body. I'm thinking the hump hose would disrupt the airflow more than the straight hose???
How does air get disrupted, when it has no other path? No carb, no venturi for fuel air mixing.. You either feed the engine with a require volume of air, or you don't. Laminar flow cannot be achieved in that short a distance, so all you need worry about, is the volume.
