[a/c problem]Usual warm driver side/cool pass. side BUT
TTT for me so I can fix my actuators
Anyone have a problem when the "AIR" comes out of all the vents and will not go to the top, middle or floor when it is selected?
Thanks,Matt
Thanks,Matt
Ac Mode Problem
Check the main vacuum line coming off the intake manifold, through the harness, and ending at the vacuum tank on the pass side hinge pillar under the battery box by the wheel well, it then goes into the cabin to the vacuum junction block and to the control head, look for a break or not connected to the intake manifold. Could be Battery Acid damage below the battery box where the lines run. If all is well with the vacum lines, it is most likely the control head.
Good Luck
HI, The most likely culprit would be either a vacuum leak, or disconnected vacuum line, or the control head is bad.
Good Luck
Good Luck
I posted this on a new thread - http://forums.corvetteforum.com/show....php?t=2076206
So if possible post on it as well so others will be able to foolow it
I will look for it tomorrow after the Vette show @ LAPD
Thanks,Matt
Since this is already brought back up I once again have the cold passenger, warm driver problem. I replaced the actuator with a new one from GM and noticed it had been replaced once before. I still get codes B0361 and B0441. I tried resetting the codes but they just come right back, I did the reset by pulling fuse 27 with the key on and off. I looked at the controller and resoldered the resistors. I put the old actuator back in and the problem is the same. Anyone have any idea what to do now? Also the freon level is fine I checked that too
AC Problems
Good Luck
4th Gear
dial stuck on 73 deg
my 2001 is hot on driver and cold on passenger and i cant change temp on my digital display it is at 73 degrees ,turn it real slow can sometime get 72 thats it, i want to take it in for a freeon refresh , refill, but not with a mechanical problem, any one please help , note i did have a broken wire o0n my hi side pressure switch, corrected that,
Hi, if you are 100% sure that your actuators are working properly, the problem has to be in one of two areas. Either the control head is not sending the proper temp signal to the dr side actuator, or the refrigerant levels are not right. Post your refrigerant pressures at 2000 rpms and what the ambient temp, and humidity is. We can isolate this problem but need the input from you so that we don't run in circles. The system is really not that mysterious. You just need to chase it down systematically. Also put the dr side temp dial at 60, and the pass side straight up, and see if you don't get cold on both sides.
Good Luck
Good Luck
Thanks Bob
AC Problems
HI BOB, It sounds like the proper amount of cooling is there, when you manually moved the actuator into the cooling position. So that leave the actuator or the control head. You said that you did the fuse #27 pull unsuccessfully. Did you place the new actuator back properly--SEE Below
Position the LH temperature valve electric actuator, then align the slots in the electric actuator driver to the flats on the LH temperature valve shaft.
Slide the electric actuator driver onto the shaft, while aligning the actuator locating hole to the forward alignment pin on the HVAC module case. The actuator driver should completely seat onto the temperature valve shaft and be the actuator mounting holes should be flush with the mounting bosses on the HVAC module case.
And then do the recalibrate properly--SEE BELOW
On the 98's you must remove the fuse #27 before removing the actuator, then replace it with the ig key in the off position and battery power in place after the new actuator is replaced. If you need to recalibrate after the install the procedure is as follows.
Re-Calibrating Actuators
Use the following steps to perform the calibration update:
Turn OFF the ignition.
Remove the battery positive voltage circuit fuse #27 of the HVAC Control Module.
Important
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
Wait 60 seconds.
Install the fuse.
If none of this works then you have to go through the detailed diagnostics to pinpoint it. It is quite lengthy so I am sending you a PM with the files to diagnose codes B0441, and B0361. Yes you could pop in a known good control head and if that works then you don't have to do the diagnostics.
PM SENT
Good Luck
EDIT, sorry don't see a way to attach files using the PM function or the email function. Send me your email and I will send you the diagnostic files, if you feel you need them.
EDIT 2-- One thing I forgot, there was a procedure to reindex the actuators on the early models pre 2001, SEE below link. Read entire thread, very informative.
http://forums.corvetteforum.com/show....php?t=1465931
The best thing to do is to make sure the new part you get is a post 2001 unit , they don't seem to need reindexing.
Edit 3--You got them bob
Important
Wait 60 seconds.
Install the fuse.
PM SENT
Good Luck
AC Problem
Good Luck
Contact this guy. He's repairs the controllers. He was a CF member at one time(mandigital.)
digitalguy_1@charter.net
I have a 99 coupe had the same problem warm on driver side cool on passenger took it down to the shop had the cooling system checked they added some freon problem gone.If you pulled the 27 fuse and heard the door move I would check the freon next.
