Need Tranny help in Camp Lejeune NC
Cruising
Ok I really need some advice for this one. I put my 98 A4 vert into drive and everything was fine. I stopped at a gas station and went I put it into park i noticed the shifter was really loose. I left the car runnig and when I let off the brake to get out the car rolled forward. Me being the genius that I am turned the car off. The shifter is loose and slides through 1-D and stops in nuetral. The shifter will go into park but it's like the car is still in drive. My car obviously will not start but everything else works. I talked with a guy at the gas station an he said he thinks that the linkage between the shifter and the tranny broke. Has anyone had this problem or is my tranny shot? PLEASE HELP!!!!
Mac
Mac
It is not uncommon for the cable on these things to break. It's a pain to replace but not too big of a job if you know what you're doing. I would recommend you ask for Donny at Marine Chevrolet and I guarantee he will get it fixed correctly. If you do take it to them, it will not be inexpensive, but be sure to ask that only Donny work on it. He's the best Corvette mechanic they have.
You can also talk to Todd at Jackson Auto Sales just up Highway 24 past Richlands in Beulaville. (910) 298-4722 His shop has completed more award winning frame offs on Corvettes than any shop in the area. They're doing a frame-off on my '63 right now but they work on all generations of Corvettes. I would highly recommend them and their labor rates are substantially less that Marine Chevrolet... just not as convenient for you. Oh and he's replaced the shift cable on a 2003 anniversary convertible with just under 100 miles on it!
Good luck... GUSTO
Good luck... GUSTO
Link up with the local Corvette club; Caro-Vettes. Talk to Jim Roddy, he has a shop on Brynn Marr Rd. in that little store complex. It's called "Fast N' Clean." Take a left at the KFC on Western BLVD if you are coming from base and his store will be on the left.
He can help you diagnose the problem. We also know a very good mechanic that does excellent work for low prices. Good luck. I'd help but I'm not exactly home at the moment
Cruising
Thanks gents for all the advice. I've been looking for some people around here that work on vettes. I will link up with Caro-vettes and I will check the shops you recommended.
Cody
Cody
