Cruise Control Issue
Hi,
I have a 1998 vette that has a fussy cruise control. It works fine on smooth pavement but dis-ingages on rougher roads. Very frustrating on long trips. Thanks for any input.
Bob
Bob
Received 8,957 Likes
I agree. Turn off the Traction Control or Active Handling if you have it and see what happens.
Bill
Bill
Received 1,680 Likes
Mine might disengage at anytime and not particularly on rough pavement. It will do it about once a day on a long trip.
It might be the clutch/brake switches are not adjusted quite right and a slight bump or body movement might cause the switch to disengage.
Mine will disengage if it perceives I have too much speed in a corner. Like not disengaging it on the clover leaf and off-ramps. I have never had it disengage other wise. It is connected to the yaw sensor or G meter. I run with the active handling off if the pavement is dry.
The C4 corvettes Cruise Control was a function of a vacum line. Are the C5's the same? Any chance one of your vacum lines has a slow leak which works during "easy Crusing" but not during the more complicated stuff?
Try pulling down on the plastic panel under the steering colum.There is a switch activated by the clutch that is mounted there and its tempermental.It thinks you are engaging the clutch and that turns off the cruis control.
Mark
Mark
