Help***Tire Pressure Sensors*** How to Delete out on a 99 FRC
Is there away to delete the TPS (Tire Pressure Sensor) warning messages on the DIC for 1999 FRC ??
Tired of getting TPS error messages looking for away around the issue.
Anything is possible .... but it would be a PITA .... and I suspect it would cost more to buy both a PCM and a BCM and get them programmed to work in your car than to just buy 4 TPMS and put them in the car.
Is it the cost of the TPMS, or is there some other reason you don't have them installed (won't fit tires ... whatever ....) ...... there arer a few alternatives less drastic than replacing both the PCM and BCM.
I'll have to look at the pin assignments for the 2001 vs 1999 and see if there is a bunch of differences.
I don't see why a 2001 BCM won't work in a 1999 as the 1999 - 2001 share the same PCM.
Maybe someone has done this already.
I've thought about it a little bit .... about the only "bump in the road" I can think of is how you'll get the BCM programmed .....
If you take it to a dealer and they use the "normal" way to program the BCM ... it'll end up with 1999 software (if it would even load) because when the dealer puts your VIN into the TIS it will return 1999 software ....
So, either you will have to pay the dealer to "manually" configure the BCM as a 2001 with your VIN and the options that you want ....
Or, you'll need a Tech2 to do the programming and configuring yourself.
If another answer hits me I'll post again .....
They have a Tech II. My vette is a 2001 so we could use that VIN to initially program the BCM for the 1999 FRC and then manually change the VATS info so that the BCM and PCM talk to each other and then code out the options we don't need.
Received 8,928 Likes
Not sure why you would care if the PCM is locked or not. The PCM has nothing to do with the TPMS. Why don't you just fix the car so it works properly instead of looking for expensive solutions to screw it up.
Bill
Bill
Thanks for help. I have to get a new PCM so I'm hoping that the local shop guys that I know will be able to do it.
The BCM (and therefore the PCM) have to be programmed as a 2001.
What might work is if you take the VIN of a real 2001 (You could use mine) and use that to program the PCM and BCM. Once they are programmed, manually change the VIN to your correct VIN and then install them in the car. Now you have a BCM that is a 2001 so you can turn off the TPMS system.
Does that make sense ... even I'm getting confused ...
* It has been damaged by battery acid
* It was locked and has an unknown tune ... and given ajg1915's penchant for f**king with anything that isn't literally "nailed down" in his car it's gotta be driving him nuts to not be able to "play" with the "tune"
then he's making the illogical leap to the question "Well couldn't I replace the BCM at the same time and "fix" the TPMS issue ...."
Agreed, totally irrational ... but at least ajg1915 is fun to discuss this with. Like me ... he knows just enough to be truly dangerous ....
Even crazier ... he's already converted the car from an Auto to an M6, and is somewhere along in a project to turn his coupe into an FRC ... check out his profile ... he's just crazy enough to try this .... I admit it's kinda like goading the "dumb" kid to jump off a roof ... but then that's my personality .... I'll always be the one in the crowd yelling "jump" ....
Not looking for expensive solutions to screw up the car. Had a bunch of problems with the car due to some asshat not properly installing blower fan that caused the air-conditioner to leak all over the BCM and interior of car.
As a result of all of this the car got column lock and was sent to the dealer who did the latest fix, however when they went to reprogram the car it got all screwed up because the PCM was locked.
Now the remotes can not be programmed nor do they work. The 1999 FRC has the passive key fobs which are pretty expensive, etc ...
Since the PCM has to be replaced as part of it's overhaul so that a new tune can be done since it's getting heads / cam, headers, CAI, etc ...
I thought now is the time to clean up this and the rest of the problems.
The car has been stripped down to the frame. All of the body panels, suspension, brakes and drive train have been removed.
The frame was covered in rust and corrosion from salt damage and battery acid damage. Once it's all clean up and painted I'll start putting it back together.
I think he is saying that he needs to replace the PCM for two reasons ...
Just trying to find a better way. Necessity is the mother of invention.
