Windshield Wipers Stuck
Hi, my 2002 Z06 windshield wipers are stuck on the windshield. Tried searching the threads but need help. Where exactly is the wiper motor and also the udders. Not sure if pressure washer would do the job for the udders. I've had the car since 2005 and just drive occasionally. Any help with pics or your thoughts would be greatly appreciated. Also is there anywhere I can get a manual that is decent.
When you say stuck on the windshield, do you mean the blades are stuck, or the wiper arms aren't in the park position? The wiper motor is under the cowl on the drivers side. You need to remove the wiper arms then remove the cowl. The udders can be found on the far left side of the wiper motor tray. You'll see three low spots, on the under side are the udders. The same on the passenger side. When you find them, add some water, then reach from beneath and milk them like *****. That should clean them out.
Thanks Carl.
