Trunk doesn't close
Old 06-12-2008, 02:56 PM
01QSZ06/3
01QSZ06/3's Avatar
Default Trunk doesn't close
I have an 01 Z and every once in a while when i try to close the trunk it doesn't want to latch. Some times it takes two or three tries before it latches. I notice that when i hit the trunk release button it sounds like the lock almost resets itself normally and then i know i will be able to close it. But when i don't hear that noise i know it's going to give me problems. So i don't know if it's electrical or the locking mechanism itself or what.
Old 06-12-2008, 04:06 PM
DPG
DPG's Avatar
St. Jude Donor '06
spray some wd40 on the latch and close it and open it a few times. the latch just may be getting stuck
Old 06-12-2008, 04:37 PM
AU N EGL
AU N EGL's Avatar
Try closing your trunk with the door open.
Something if the car is closed up tight the trunk or hatch back wont close
Old 06-12-2008, 05:31 PM
DPG
DPG's Avatar
St. Jude Donor '06
this can be it too. try it with the window cracked open
Old 06-12-2008, 08:42 PM
T VETTE
T VETTE's Avatar
Ditto
Old 06-12-2008, 09:47 PM
oakvillec5
oakvillec5's Avatar
Old 06-12-2008, 11:47 PM
bestvettever
bestvettever's Avatar
Default Trunk Latch
Hi, wd40 on the latching mechanism should do it.
Old 06-13-2008, 07:31 AM
9secondflat
9secondflat's Avatar
you have to stop putting those bodies in your vette....old lincolns work much better....
To Trunk doesn't close
Quick Reply: Trunk doesn't close
