Water pump bolts?
06-10-2008, 01:34 PM
Water pump bolts?
Should I put some antiseize on the water pump bolts or any type of tread sealer when installing the new pump?
06-10-2008, 02:29 PM
St. Jude Donor '06
just clean em and put some thread locker on them. i believe its 22ft lbs for torque spec.
06-10-2008, 06:53 PM
I don't use loctite on them, service manual calls for dry installation. Tighten in two passes, first pass at 11 lb-ft, second pass at 22 lb-ft.
06-10-2008, 07:05 PM
Location: Dear Karma, I have a list of people you missed.
Mine were showing early signs of corrosion. Anti-seize.
06-10-2008, 07:12 PM
100000 miles and just replaced mine bolts came right out.
