AC blows from defrost, front and floor
Old 06-08-2008, 10:19 PM
Bunk930
Bunk930's Avatar
2018 C6 of Year Finalist
Default AC blows from defrost, front and floor
I think there is a vacuum leak but I don't have the time or patients to fix this. Does anyone have any idea how many hours the dealer will charge to fix this?
Old 06-08-2008, 10:55 PM
bestvettever
bestvettever's Avatar
Default Vacuum Leak
Hi, sorry I can't really help you on what the dealer will charge to fix your problem, it depends on how much diagnosis they have to do to determine if that is the problem and where the leak is. Could be an hour, or many hours.
Normally those kinds of leaks are either a hose breaking off from the connection at the back of the manifold, or a line being eaten up by battery acid under the battery box.
If it is a back of the manifold situation it is tough to get to, but some have done it without taking the manifold off and fixed it in a very short time. If it is the battery acid situation you have a larger problem, and will need to not only fix the vacuum line, but clean up the whole area and fix any other lines, wires or computer parts that have been damaged.
Good Luck.
Old 06-08-2008, 11:36 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Good Luck.
It's proabbly the vaccum lines to the canister. Cost will be pretty high because intake manifold will need to be removed to access line on back of manifold.
Big Black Canister in picture by door.
Old 06-08-2008, 11:39 PM
Bunk930
Bunk930's Avatar
I have an optima battery in the car do they leak acid?
Old 06-08-2008, 11:48 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Not unless they get cracked.
Old 06-08-2008, 11:51 PM
Bunk930
Bunk930's Avatar
Is it possible to reach back behind the intake manifold to check? By just looking it could be tough
bestvettever
Default Optima doesn't leak
Hi, no the optima won't leak, but what was in the car before the optima may have leaked and done some damage that is showing up now. It is not hard to see if you look down under the battery box with a flashlight. If not the under battery area, it is probably the back of the manifold situation. If you are a bit handy and can spare a little time you can probably fix it your self. If you need the dealer to do it, they will probably charge you to remove the manifold and repair it. Many hours.
Good Luck
Old 06-08-2008, 11:56 PM
bestvettever
Default Vacuum Leak
You could possibly do it, although it is tight, use a flashlight and a mirror to get a look at it.
Old 06-09-2008, 12:06 AM
Bunk930
Bunk930's Avatar
thanks guys I will try it
Old 06-09-2008, 12:14 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Look from the passenger side.
Old 06-09-2008, 12:54 AM
Blue Blood
Blue Blood's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
I kinda have the same problem and I also have a hissing sound coming behind the main instrument cluster, and the air I'm getting is warm and it's all the time, are these possibly related? If so, is the GM extended warranty likely to cover?
Old 06-09-2008, 01:49 PM
RyanR0101
RyanR0101's Avatar
Mine had the same problem and was leaking vacuum behind the intake manifold. The dealer wanted $400+ to fix it.
Old 06-09-2008, 05:27 PM
Bunk930
Bunk930's Avatar
was the hose bad or was it disconnected?
Old 06-09-2008, 06:10 PM
Bunk930
Bunk930's Avatar
If you have an extended warranty it is probably covered
To AC blows from defrost, front and floor
Quick Reply: AC blows from defrost, front and floor
