Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-21-2001, 10:33 AM   #1
chuckster
CF Senior Member
chuckster's Avatar
Send a message via AIM to chuckster
Default What type of grease do I use on the Caliper Bracket Guide pins???
I had my Caliper Brackets Nickel/Zinc plated. I had to remove the guide pins. Now I am ready to clean and regrease them and need to use the right lubricant.
I have a tube of White lithium grease. Will this be ok for that purpose?
The manual makes no mention of the grease type needed...
chuckster is offline   Reply With Quote
Old 12-21-2001, 10:45 AM   #2
CHJ In Virginia
CF Senior Member
CHJ In Virginia's Avatar
Default Re: What type of grease do I use on the Caliper Bracket Guide pins??? (chuckster)
The best product to use is a silicone based grease. Your auto parts store should have several types available made specifically for brake applications. It will not harden with age or heat. When assembling, also be sure to put a small amount at the points where the pads seat in the bracket and where the caliper meets the backing plate of the pads. This will go a long way towards keeping them quiet.
CHJ In Virginia is online now   Reply With Quote
Old 12-21-2001, 11:06 AM   #3
carpe dm
CF Senior Member
carpe dm's Avatar
CHJ is right; use silicone grease or "dielectric" grease and you will be OK. :)
carpe dm is offline   Reply With Quote
Old 12-21-2001, 11:13 AM   #4
Jim 47
CF Senior Member
Jim 47's Avatar
Chuckster;
I recently bought some synthetic brake caliiper grease. It's made by CRC and the part No. on the package is SL33011. Their number is 800-521-3168, if you want to call ablut where you can get it in your area. This product looks real good for what you have in mind. :yesnod:
Jim 47 is offline   Reply With Quote
Old 12-21-2001, 11:22 AM   #5
chuckster
CF Senior Member
chuckster's Avatar
Guys I don't need grease for the pads...
These are the actual Guide PINS that go into the caliper Brackets. It's the pin that the Caliper bolts get bolted into. I suspect it needs to be a high temp grease.
Old 12-21-2001, 11:46 AM   #6
chuckster
CF Senior Member
chuckster's Avatar
TTT
I am right in the middle of this project....I guess I can't go wrong with wheel bearing grease...
Old 12-21-2001, 12:07 PM   #7
PeteL
CF Senior Member
Location: And on the fifth day, subpoenas were served to Obama senior staff
Wheel bearing grease is exactly what you don't want on those pins. You need a high temp silicone brake grease, not dielectric grease.
GM make a very good lube for brakes, but comes in a very large tube. You can try Permatex's Ultra Disc Brake Caliper Lube P/N 20356 which comes in those little squeeze tubes and is very good.
Good Luck,
Pete
PeteL is offline   Reply With Quote
Old 12-21-2001, 12:15 PM   #8
willi
CF Senior Member
Chevy manual says silicone grease.
willi is offline   Reply With Quote
Old 12-21-2001, 02:09 PM   #9
chuckster
CF Senior Member
chuckster's Avatar
Default Re: What type of grease do I use on the Caliper Bracket Guide pins??? (PeteL)
These are the Guide pins that go into the the caliper BRACKET. They are 3 inches long. This question has noting to do with the brake pads...
Sorry, for the rant. I can't explain it any better than I have.
[Modified by chuckster, 4:13 PM 12/21/2001]
Old 12-21-2001, 02:19 PM   #10
PeteL
CF Senior Member
That was the question I answered.
Old 12-21-2001, 03:08 PM   #11
Jim 47
CF Senior Member
Jim 47's Avatar
Hey Chuckster, I can't be more precise, the CRC synthetic brake calaper grease that I recommended IS a high temperature grease that is suitable for the guide pins or any other part that need lubrication on your brakes. I think we all know what you are talking about, and are trying to provide good advice. For pete's sake don't use axle grease or regular grease on the pins. Use the high them CRC grease that I originally recommended. It will work fine. Believe me, I have used this grease. :cool:
Old 12-21-2001, 03:36 PM   #12
PeteL
CF Senior Member
Default Re: What type of grease do I use on the Caliper Bracket Guide pins??? (Jim 47)
Or you could try K-Y jelly.
I think he should not use it for Chuck's sake :D
Old 12-21-2001, 03:54 PM   #13
Jim 47
CF Senior Member
Jim 47's Avatar
Right you are PeteL. Happy Hollidays :D :D :D :D :D
Old 12-21-2001, 06:16 PM   #14
chuckster
CF Senior Member
chuckster's Avatar
Jim, I found 450 Degree Silicone grease at Ace Hardware. Is this OK????
Old 12-21-2001, 10:36 PM   #15
FUN4JT
CF Senior Member
FUN4JT's Avatar
Actually I've found 450 degree silicone lubricant is a dual purpose lubricant, works much better then KY. :lol:
FUN4JT is offline   Reply With Quote
Old 12-21-2001, 11:10 PM   #16
Bill Dearborn
Bill Dearborn's Avatar
Default Re: What type of grease do I use on the Caliper Bracket Guide pins??? (FUN4JT)
I use Permatex Anti-Seize compound on my calipers. I put it on the pins and at all points where two metal surfaces will slide across each other. This includes the pad mounting points on each end and for the C5 in the center of the backing plate where the caliper spring touches the plate. The Permatex stuff is good for exhaust system parts and stays slippery. Advance Auto Parts sells a different anti-seize compound that should not be used since it gums up after a while.
Bill
Bill Dearborn is online now   Reply With Quote
Old 12-21-2001, 11:18 PM   #17
PeteL
CF Senior Member
Default Re: What type of grease do I use on the Caliper Bracket Guide pins??? (Bill Dearborn)
That's very interesting, but you are using the wrong goo. These parts require a very high temp lubricant, not anti-sieze. If you read the shop manual and listen to the posts when somebody asks, you will find that there is the correct product for the job. Using this knowledge will prevent future posts that contains topics like: I rebuilt my brakes last year, why does my car pull to the right and the pads are not wearing evenly? :D
Old 12-21-2001, 11:26 PM   #18
Bill Dearborn
Pete,
I have been using this stuff on all of my cars and trucks for over twenty years and have never had a problem. When I have replaced pads after several winters of running through salt and sand I have always found the Permatex Anti-Seize to be still slippery and it kept the areas where it was used from rusting and preventing the caliper from freezing up. Biggest problem is getting the stuff off if you get it in the wrong place. If it can take 1300 degree exhaust heat it sure can take 1000 degree brake pad heat. That is also why I said to use the Permatex Anti-Seize and not some other brand.
Bill
Old 12-21-2001, 11:44 PM   #19
PeteL
CF Senior Member
Bill, can't argue with experience. I've never tried a really good anti-seize as a brake component lube. If this can take exhaust temps it must have the little glass beads in it, which is interesting to consider in a brake application.
To eat some crow, that's why we all read the forums! :D
Old 12-22-2001, 12:42 AM   #20
chuckster
CF Senior Member
chuckster's Avatar
ttt
Is it ok to use 450 degree silicone grease
Reload this Page What type of grease do I use on the Caliper Bracket Guide pins???
Tags
anti, brake, caliper, corvette, crc, grease, guide, kind, permatex, pin, pins, seize, synthetic, type, ultra, vs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
