Clutch Nightmare to Clutch Heaven
#141
There are many threads on this subject. The TICK master cylinder FIXES all the problems with sticking clutch/ high RPM shifting issues,etc.. Just type Tick master cylinder on search. Our clutch master is the weak link on the C5 driveline.
#142
I would agree about the master cylinder and when mine screws up I will replace it with a tick. Notice they use a larger lines. In my MHO its about moving the fluid quickly . Do you have a tick master on yours? I so how do you like it?
#144
ive had the sticky pedal with an ls7 clutch, tried all that time consuming bs, nothing worked either. The main reason for the sticky pedal is heat, whether it be in your hydrolics, or clutch assembly. Mine was due to heat on the pressure plate making the clutch plate itself stick to the pressure plate. I am going to a monster stage 5 and hopefully that will solve the problem. from all the reviews and the chats with the dealers they handle the heat better then most twin disc set ups. Swapping to a better flywheel that can handle the heat better should also help eliminate the problem.
#145
i have a strange problem, i had in my c5 z06 H/C pakadge, and spec 3 + and hurst shifter and it maid 440rwp, trap 123mph 1/4, and was very good in power shifting, could shift so fast....
then i changed out my 346ci for new ls2 402 and new cam, but used all my other parts, for some reason i ordered a new clutch disc, because some thought it was a little bit worne but the PP was ok, alignend the flywheel, but i didn´t get spec 3+, instead only spec 3 (6 arms) disc, but i putted it together, after i asked them in spec if i could.
now i have done whith breake in about 850 miles, and started to rev it up, and it´s hard to put it in gears on high rev, can not power shift it, put the pedal is not so sticky at all, always comes back up again.
what can this be?
what can this be?
#146
I had LGM install an Exedy twin plate in 2006 for my H/C 346 rated at 457 rwhp 417 rwtq. I have since grown to a 541 rwhp 505 rwtq ls2 402 and still running the exedy twin plate. No issues at all.
Vengeance Racing showed me how easy it is to remove the bad clutch fluid and just refill. As the fluid is cycled through the system the bad black crap is forced to the top. Repeat the process until only clean looking fluid remains. Check weekly if you drive your car a lot, race, or just to be **** retentive. Hope my comments helped.
#147
So I bought the Centerforce 12" Dual Friction Clutch, really good price.
Its sitting on my shelf, I haven't had a weekend to install it yet. I'll try to get it installed along with a new slave (again) sometime in July... hopefully...
I'll post my results if the sticky pedal problem goes away
Dan
Dan
#148
Location: Big D' home of Da Boys- aka - America's TEAM!
Dan
Dan
Have all of you been making this swap at home or paying out labor? Doesn't look as easy as my past stangs and way more time consuming!
#149
I really need to get the swap done this summer, but I'm not sure thats gonna happen...
I'll be sure to post when I do.
I've done the work at home (on a slave so 90% of a clutch job) and its not too bad, takes all weekend, but nothing really hard. There's good writeups on the swap available online.
It takes a while, so paying for the labor would be a pretty penny...
-Dan
#150
I've done 4 or 5 now and it's way faster after the first couple. (I have a lift so that helps a lot)
If you tranny comes out with this much still attached then you've done it just about as fast as possible
Did I mention that I have 46,000 miles on my Exedy twin disc? Did I mention I have at LEAST 550 whp? Did I mention that I drive it like I stole it? Just thought I'd mention that.
#151
Thanks for the fast replies!
More than likely, probably on jack stands if I can even get the car high enough....
Great picture!
Great picture!
#153
Or
Look above the clutch pedal and see if your clutch master is leaking down onto the carpet or behind it on the firewall.
#154
I haven't had a chance to swap it. I've been so busy this summer with work, and my Econobox crapped out on me, so now I'm daily driving the Vette I can't have it out of service for a weekend...
-Dan
-Dan
Did you ever get around to swapping out that Clutch? I'm running into the same problem on my '04 and am looking into putting in a new clutch, from what I've read on your 8 page post...Centerforce seems to be the way to go but wanted to know how you made out, if it stopped the sticky pedal problem and what you think before I go ahead and do it. Great Post BTW.
Ron
#157
I think I'm gonna give Tom a call at Wong's Performance Engineering... I'm tired of waiting to have a chance to install this clutch, and I'm not sure I'll ever get around to doing it myself... LOL Things have been too crazy for me...
I still haven't forgot about this thread... I'll be sure to post my results when I get it done...
Centerforce 12" Dual Friction <crosses fingers>
-Dan
-Dan
#158
I have had sticky clutch on my head and cam SS and on my vette. I installed the tick master on both cars and never had a problem. My friend also did a tick on his head and cam vette and no problems on his either.
#159
I did exactley the same with the same results.
Before I did this I did the ranger method with about 100 bucks worth of fluid and no change in clutch performance. I didn't even to be rodding mine for it to hapen. I could let the clutch out on a normal 1-2 shift drive 1-200 miles, nail the gas and when it was time to catch 3rd there was no one home, pedal on the floor. I replaced the master and flushed more and no luck.
Replaced the clutch and slave and added a remote bleeder and the problem has never resurfaced. I shopped for a while and the most economical way to do this was:
12"CenterForcec from Summit 360
F1 flywheel off Ebay for 160
Pilot and slave from the local dealer.
No problems since.
I did find when I cracked mine open the the clutch appeared to be in good shape and the car already had a Fidanza Aluminum flywheel in it(that is for sale BTW), but it looked like a stock clutch.
Good luck.
No problems since.
Good luck.
#160
Good thread this...some real interesting posts too from all angles... although i gotta admit, im more so swung toward believing its all down to the PP.
I notice theres alot of guys posting without stating what power the car is, or what mods are done.
I DONT have the sticky pedal problem, have a full intake, L.T headers, x-pipe, high flow cats and tune... and making about 385 RWHP on last dyno..
But ive bought a new cam (whipelash ii) pulleys, Valve springs etc and injectors, so with a new tune it should be making well over 400RWHP.. but i dont want to get the car going, and imediatly have to put it back up on the ramp for a clutch, so i was planning on doing the lot at once.
I was originally going with the tex.. but there does seem to be a few persuading problems with them to stop me wanting that clutch.. so it seems my next best options are a 12" centreforce, spec3 or a twin exedy.
I hear the spec three can take away from drivability, and i understand the centreforce seems to keep a fairly stock feel?? nothing though on this front about the twindisk (although it took a fair amount of time reading all 8 pages, so perhaps i may have forgotten! haha)
So whats the pricing like on the 12" centreforce and twin exedy?
Postage to irelands not cheap.. so ide like to get this right 1st time round! ha
ALSO.. my cars an 03 Z with 9000 miles on it... is there REALLY a need to change the hydraulics>?.. i dont want to be going in there twice, so i understand changing them on a 'just incase basis' ... but at only 9000 miles?
