C6 Z06 shifter in my C5. Does it need modified?
1 Post
St. Jude Donor '08
It does not need to be modified. Just make sure you buy the entire unit.
You can get it at GMPARTSWAREHOUSE for a great price.
Here is a link.
http://www.gmpartshouse.com/
I have one in my car and many other people have installed it also with great results.
Here is a link.
You will likely have to modify the shifter boot. I had to cut the top of the boot on mine to get it to fit over the bottom of the shift ****.
Little tip too.. once you cut the boot and get the shift **** on you can turn the boot inside out over the **** and use a zip tie to hold it tight around the bottom of the **** (there is a little groove around the bottom of the **** that you can zip tie around). When you fold the boot back down it should look like it has always been made for the shifter.
Here is a link.
Here is a link.
thanks in advance
May I suggest you do more research before taking on a mod...most have been done before and with a little effort using the search feature you can find help like this: http://forums.corvetteforum.com/show....php?t=1022661
coast7
coast7
C6 shifter assy
[IMG][/IMG] The entire assy includes the shift box[IMG][/IMG] This link may be of help as well:http://forums.corvetteforum.com/show...c6+zo6+shifter
alright search ****....i did search...found an old related thread and posted on that one instead of making a new one
coast7
coast7
Premium Supporting Vendor
Purchase from GM Parts House!
||--Genuine GM C6 2009 Z06 Shifter Kit--||
25823571 – C6 Z06 shifter
10354701 – C6 shift ****
11609670 - Bolt
Complete kit 193.49
For this kit on our website, use part number c6z06shifter under Chevrolet make.
This shifter kit works on all C5’s.
The C5 boot will either need to be modified or you’ll have to purchase an aftermarket boot for a C5 that fits a C6 shifter.
11609670 - Bolt
Complete kit 193.49
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
