A4 front pump seal
Old 06-08-2008, 02:25 PM
verano29
verano29's Avatar
Default A4 front pump seal
If installing a yank ss3600 converter this weekend. For those of you who have installed the converter did you also replace the front pump seal? I have the seal but I don't really have the tools to remove it and I don't want to pound a screw driver against soft aluminum to remove it. Does this seal fail often? It wasn't leaking before (I'm at roughly 40k miles on my 98) should I expect it to leak afterwards.
I
Old 06-08-2008, 02:41 PM
verano29
verano29's Avatar
If I pick up a regular seal puller from autozone will this work for the front pump seal?
As far as the install, should I have a special installation tool or would "walking" around it with a hammer work. I've done that back in the day and it seemed to work fine...but I'm older and wiser now and I want to make sure it seats correctly.
How did you guys do it?
Quick Reply: A4 front pump seal
