Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-09-2008, 01:08 AM   #1
Itallian33
CF Senior Member
Itallian33's Avatar
Send a message via AIM to Itallian33
Default Targa Top Refinsh How-To
Well, I have learned a lot over the last year from reading this form, and this is my attempt at writing up a how to.
I bought a used clear targa top in the parst section for a good deal. Thanks to David Wilson (doje) for a great transaction. He was very clear about the condition of the top and it was a pleasure dealing with him. That being said the top was hazy and in desperate need of attention.
EDIT: I get emails and calls from people attempting this, and there seem to be mixed results with the sanding. The top I purchased was completely hazy and all of the "Hardcoat" was crazed. (see before pictures below) This, I think, made it easier for me to sand the hardcoat off. I have hear from people haveing a very hard time removing their hardcoat if it is in good shap. Just a FYI.
This is what it looked like when I got it ( actually these pics are from the ad)
Click the image to open in full size.
All you need to refurbish the top is:
1000 grit wetsand paper
1500 grit wetsand paper
2000 grit wetsand paper
Rubber sanding block
Squirt bottle
Dish soap
Shammy
Terry towels
Porter Cable Polisher
Meguieres medium cut, Fine cut, and swirl remover
EDIT: If the Hardcoat on your top is in better shape than mine you will probably want to use a coarser paper and the assistance of a mechanical sander. Do at your own risk. I have verry little expierence with mechanical sanders and can no offer advice in this regard.
First thing I did was to remove all of the old clear coat and the oxidized plastic from the top. I just used 1000 grit and wetsanded it down. This took about 3 hours to accomplish. It was easy to tell if I was finished because you can look at a light through it and see where it was fully sanded or not. A tip for wetsanding. I used an old shammy to continually clean the surface i was sanding. This makes it easy to remove all of the material from sanding and it the surface will quickly dry so you can tell what areas need more attention.
There are two ways to finish the top from here. At this point it is ready for paint or clear coat. I sprayed a thick layer of PPG clear coat that I had laying around on it. This gives the acrylic UV protection and gives more material to polish out. It is recommended that the surface be sanded down with 600 grit, but I just kept it at 1000 because I was scared of using that course of paper on the top. The coat has stuck fine so far.
(EDIT: I got some requests for the type of PPG Clear that I used. It is Deltron High Velocity Clearcoat. DC3000)
I am not the best with a paint gun so the finish had an orange peal effect to it. I wet sanded the top again, this time with 2000 grit paper in preparation for polishing it. Looking back I should have started with 1500 grit and then worked my way up to 2000, but again, I like to start with a finer paper and just do extra work so I take off as little material as possible. When sanding for polish, always sand in one direction, then when you step up to the next grit, sand 90degrees to the previous grit. Keep sanding till you can’t see the marks from the previous grit. The following picture is where I started sanding the top after paint and you can easily see the orange peal.
When you get the whole thing sanded out, you are ready for polish. I used a PC 7424 to polish it out, but any polisher will do. I started with the medium cut cleaner and worked it till all of the sanding marks were removed from the finish.
The medium cut cleaner does a good job of removing the sanding marks, but does leave the finish on the top hazy. I steped up to a fine cut cleaner and polished out all of the haze.
Then for good measure I stepped up to the swirl remove and got a great finish on the top.
The other way to finish the top is to skip the clear coat step if you don’t have access to paint gun or booth and just polish the acrylic. Step up from the 1000 grit finish to 1500, then 2000, alternating directions each time. Then polish as mentioned above.
You might also be able to find a local shop that can spray the clear for you for a good price. That way you won’t have to mess with buying the clear and getting a booth and a charcoal mask to protect yourself from the fumes.
Hope this helps someone.
Jason
Itallian33 is offline   Reply With Quote
Old 05-09-2008, 07:43 AM   #2
beav626
CF Senior Member
beav626's Avatar
Send a message via Yahoo to beav626
I know a lot of C5's are gonna need this
beav626 is offline   Reply With Quote
Old 05-09-2008, 10:42 AM   #3
patrickC5
CF Senior Member
patrickC5's Avatar
Real good write up I may try it this year. The clear on my top is peeling real bad on the passenger side and looks like crap.
patrickC5 is offline   Reply With Quote
Old 05-09-2008, 12:12 PM   #4
indieaz
CF Member
Night and day difference. My top is getting pretty bad too, i might have to try this.
indieaz is offline   Reply With Quote
Old 05-09-2008, 01:18 PM   #5
damilleniumboy
CF Senior Member
damilleniumboy's Avatar
Nice write up .
damilleniumboy is offline   Reply With Quote
Old 05-09-2008, 05:36 PM   #6
dave2007
CF Senior Member
dave2007's Avatar
Learning things the hard way sucks. I am glad people like you are willing to pass on very good info and how to's with no expectations to gain from it. Nice Job!
dave2007 is offline   Reply With Quote
Old 05-09-2008, 05:47 PM   #7
SteveDotenMotorsports
Former Vendor
Cruise-In VII Veteran
SteveDotenMotorsports's Avatar
nice fix, 90% of the clear tops seem to peel on the pass side
SteveDotenMotorsports is offline   Reply With Quote
Old 05-09-2008, 07:00 PM   #8
screw991le
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Send a message via MSN to screw991le
That is one of the first refinishes that I have seen work. Most people paint it. Awesome job. How much time did it take you?
screw991le is offline   Reply With Quote
Old 05-09-2008, 07:08 PM   #9
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Quote:
Originally Posted by damilleniumboy View Post
Nice write up .
Really!
jrose7004 is offline   Reply With Quote
Old 05-09-2008, 07:53 PM   #10
Itallian33
CF Senior Member
Itallian33's Avatar
Quote:
probably about eight hours all told, but like i said, using courser grit paper and then working up to 2000 on the wetsanding would have gone a lot quicker, but i am was scared of messing up the top. Someone who is better at it could have done it in half the time.
Thanks for the kind words everyone. I am no professional so if i can do it anyone can.
Old 05-09-2008, 09:12 PM   #11
grady
CF Senior Member
grady's Avatar
Mitchell Kennedy
Perfect will try doing this soon
grady is offline   Reply With Quote
Old 05-09-2008, 10:25 PM   #12
jon c
CF Senior Member
jon c's Avatar
Awesome job Jason, cant wait to see it in person,
jon c is offline   Reply With Quote
Old 05-10-2008, 09:47 AM   #13
JCSZ51
CF Senior Member
Cruise-In IX Veteran
JCSZ51's Avatar
great job!!!
JCSZ51 is offline   Reply With Quote
Old 05-10-2008, 10:01 AM   #14
Bobz08C6
CF Senior Member
Is the C5 roof different from the C6 roof? I had a mar that was through the hardcoat on my 08 C6 with only 300 miles on it. I talked to the roof GM engineer, the roof supplier, the hardcoat and polycarbonate panel supplier and several plastic refinishing suppliers and all said the same thing. Once you penetrate beyond the hardcoat there is no fix and that abrasive finishing will not work. They even suggested that a touch up with a sample of liquid clear coat would not look acceptable. I ended up getting a new clear roof.
Were your defects NOT through the hardcoat? Also, I thought the roof panel (at least on the C6) is polycarbonate and not acrylic.
Your thoughts?
Bobz08C6 is offline   Reply With Quote
Old 05-10-2008, 05:16 PM   #15
jedblanks
CF Senior Member
jedblanks's Avatar
My targa was in pretty rough shape similar to the 1st picture on here.
I used 2000 grit wetsand paper with soap and water and a sanding block $7 total at wal-mart
Some Meguiars Medium Cut, Some turtle wax polising compound, and some 3m finish restorer (swirl remover) in that order.
Then a coat of wax. Looks decent, without as much work. Still a few close up flaws, but 1000 times better without having to re-clear.
I'd say if your final finished product was a 10, mine was a 9. And a grand total of $20 spent.
Oh and one more thing -- thanks for the writeup on how to do this. I now have a nearly new looking targa top instead of a paperweight taking up space in the shed.
jedblanks is offline   Reply With Quote
Old 05-10-2008, 10:04 PM   #16
Itallian33
CF Senior Member
Itallian33's Avatar
Your thoughts?
The discoloration was throught the hardcoat and into the lexan. i assume it is made of lexan since it has a stamp that says lexco, or lexmar or something similar on it.
That is awsome. I thought about just doing that, but i had the clear left over from another project, and thought what the heck. Glad to hear someone else had luck redoing these tops. They are sooo expensive not to try
Old 05-10-2008, 10:40 PM   #17
peachtreeplaya's C5
CF Senior Member
peachtreeplaya's C5's Avatar
peachtreeplaya's C5 is offline   Reply With Quote
Old 05-11-2008, 12:39 AM   #18
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
Damn, Nice work
clayton1 is offline   Reply With Quote
Old 05-11-2008, 10:19 AM   #19
SUPERCRUZ
CF Senior Member
SUPERCRUZ's Avatar
You do nice work. Compared to what you started with, the finished product looks awesome. Thanks for the step by step instructions and pics. I am sure this thread is going to come in handy for many forum users.
SUPERCRUZ is offline   Reply With Quote
Old 05-11-2008, 11:43 AM   #20
SMaster
Senior & Fat Fingered
Support Corvetteforum!
SMaster's Avatar
Nice job! Mine has the passenger side flaw in it too.
Has anyone ever considered covering the top with black vinyl? Seems like it should work.
Steve
__________________
___________
SMaster
-------------------------------------------------------------The Beauty ----------------------------------- The Beast
SMaster is offline   Reply With Quote
Reload this Page Targa Top Refinsh How-To
Tags
acrylic, c5, carbon, clear, coat, coating, corvette, fiber, hazy, polish, refinish, refinsh, remove, scratches, targa, top
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Deep scratches removed from glass top seegeer C5 Tech 5 08-30-2013 01:13 PM
Tinted my Eagle Eyes and installed them.... JRHAWK9 C6 Corvette General Discussion 33 06-16-2013 07:27 PM
OEM Z06 Polished Speedlines ddanis60 C6 Parts for Sale/Wanted 4 12-10-2012 07:25 PM
test Floridasky Testing 0 11-08-2012 12:28 PM
"How To" fix curb rash on polished lips (pics) DRKMATTER C5 General 40 08-07-2012 04:23 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
