putting ls2 in a c-5?
Old 04-26-2008, 11:59 AM
walk away
8th Gear
walk away's Avatar
Default putting ls2 in a c-5?
looking to put a ls2 in a c5. does ayone know what wiring/ecm problems need to be addressed? thanx
Old 04-26-2008, 10:12 PM
nj02vette
nj02vette's Avatar
Location: Marlton. Increasing performance one speeding ticket at a time! NJ
First thing you need is the right LS2.
There are some with 28X(??) reluctor wheels, yet the C6's used 52X(??) reluctor wheels. LS2's from GTO's, CTS-V, etc would be fine. If buying a crate motor, make sure you get the right p/n.
**not sure of the exact reluctor numbers.....also I think 05 C6's have the older engine?
Old 04-26-2008, 10:19 PM
walk away
8th Gear
walk away's Avatar
Default 07 c6 motor from wreck
its from a 07 c6 wreck. ill have the ecm from it, and wiring.
Old 04-26-2008, 10:25 PM
Mike94ZLT1
Mike94ZLT1's Avatar
You would need to completely tear down the engine and change the reluctor wheel on the end of the crankshaft to the LS1 style, the newer 58 tooth is not compatible with the LS1 PCM. In addition to doing that you will need an extension for the cam position sensor, knock sensors, and if you want to run the LS2 intake you will need a wiring adapter for the throttle body and MAF as well. Not worth it for a stock LS2.
Old 04-27-2008, 11:58 AM
walk away
8th Gear
walk away's Avatar
Default back to the drawing table.
thanx for the heads up. gotta love the internet and corvette forum
Old 04-27-2008, 09:32 PM
corvettejoe98
corvettejoe98's Avatar
Get an LS6 or 7 why spend all that money and limit yourself to the LS2
Old 04-27-2008, 09:53 PM
BlackZ06
BlackZ06's Avatar
OK, maybe this will help ....
The LS1 and LS2, at a MECHANICAL level, are VERY similar. Both are V8's. both use a single camshaft to drive the valvetrain .... both are fuel injected, electronic ignition, electronically controlled (OBD2) engines.
BUT, it is on the electronic side where they differ .....
The LS1 was first sold in 1996 .... so think about it ... the computer that controls your engine dates back to about 1994 to maybe 1995.
Are you still running any computers in your house that are 13 years old ??????
Even worse, your C5 computers use a network protocol that is kinda like "dial-up" ....REALLY slow. The C6 computers use a new network called CAN (Controller Area Network) .... but that means you can't install a C6 computer in your C5.
So .... bottom line (and interesting that it ends up being this easy) if you take an LS2 engine and change the camshaft reluctor wheel to a C5 wheel, and use a couple of harnesses provided by 3rd party vendors to connect the LS2 Throttle Body to the LS1 wiring system ... your current PCM can control the newer LS2 engine ..... this is a "doable" upgrade.
Old 04-27-2008, 10:37 PM
Mike94ZLT1
Mike94ZLT1's Avatar
Because an LS7 would have the exact same issues, in addition to all the issues with converting the oiling system. The cost of an LS7 plus the amount of work and additional cost to make it work, are also not worth it.
Old 04-27-2008, 11:16 PM
ISeeRed
ISeeRed's Avatar
Why not change the reluctor wheel, and use the LS6 intake and throttle body? Then the only other change would be the knock sensor wire extension. Unless he's making other changes the LS6 intake flows way better than the LS2 and a ported TB although smaller than the LS2 unit will flow better with the LS6 intake as a pair. The other benefit is that it will look "stock" C5 if the guy wants to be stealth.
I gotta say that I'd put a cam in the thing while he's in there changing the reluctor wheel as well.
To putting ls2 in a c-5?
Quick Reply: putting ls2 in a c-5?
