Filing Complaint W/ Gm Over Cracked Wheels
I have an 02 coupe and filed a complaint with GM over the cracks in the wheels. According to this forum there are A LOT of people with this problem. It is a safety hazard. I have info on filing a complaint. PM me and I will give out the contact info. We need to do this for everyone who has had this issue. Pass it along.
St. Jude Donor '08-'09-'10
Received 8,958 Likes
I know 3 people who have had this problem. Two of them were lucky enough to have GM or a dealer help them out. Actually I don't know if anybody has ever documented the cracks as a safety issue. I have never seen anybody say they investigated the cracks and found them to be deeper than the paint.
Bill
Bill
I check my thin-spokes every few car washes... Still no cracks but please let us know what happens this is a problem that stays in the back of my mind all the time.
Take care
Take care
Thanks for your efforts to share information on this topic.
Bill
Bill
Bill
Bill
02 Coupe. My front drivers side cracked all the way through, not just the paint. Could NOT hold air. I sprung for a whole new set of aftermarket Z06 replicas from WCC. I still have the originals (3 good ones and the cracked one) and don't know what to do with them now. Any ideas?
St. Jude Donor '05
I've been through this, faught with GM for a few months, they had me take the car in to a dealer to inspect the wheel, they had to take the wheel off the car and tire off the wheel. After confirming the crack GM offered to pay half the cost of the wheel, about $325. I argued that they should pay the whole thing because it was a defective product, but they would not. So I decided to buy new Z06 reps from WCC and forget about it because even if GM replaced the wheel I'd still be worried about cracks later down the road because those wheels are prone to crack.
If you like the think spokes, try and find a set from 2003 up because they changed the manufacturer and the design slightly, which tells me they (GM) was well aware of the problem.
Wrong. Try and find the early 2000 thin spokes. These were manufactured by Alcoa and were forged versus spuncast. These are extremely durable wheels, and many track guys use to track with these wheels. None of the Alcoa wheels were polished or chrome, they all cam painted. After GM switched manufacturers (to save costs like usual), they began to have cracking issues until they switched manufacturers again due to the cracking problems.
St. Jude Donor '05
Wounded Warrior Escort '11
I just gave away a set of wagon wheels to another forum member. While moving them out of the garage, I saw that one of the fronts had a 1/2 inch crack in it that I had no idea was even there. I switched to chrome wagons a couple of years ago, so the original stock ones came off. I don't track the car and only drive it back and forth the work on the freeways most of the time.
The thin spoke was introduced in 2000 as a forged aluminum wheel available in both painted or high polish versions. The wheel vendor couldn't keep up with demand so GM changed the design of the painted wheel slightly so it could be cast instead of being forged. This design has slightly larger spokes. The forged high polish thin spokes were sold on cars through at least 2002 that I know of. However, when a friend of mine had the wheel on his in warranty 2002 crack in 2004 (about a month before production switched to the C6) the dealer ordered a new wheel to replace it and they found out it had slightly larger spokes than the 3 remaining wheels. The dealer then ordered 3 more wheels to replace the rest of the wheels. Obviously, GM has reduced the types of wheels (cast/forged) they are selling to reduce cost of replacement parts. The low level person who made that decision probably didn't realize there was a difference in the wheels.
Bill
Bill
Sorry Hightest, that is not correct. My 2002 coupe manufactured June 2002 came with high polished thin spokes from the factory. They are forged Alcoa wheels. So far no cracks. I would like particulars as to the manufacturer of the cracked wheels
