Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-25-2008, 11:59 PM   #1
vetteguy0483
CF Senior Member
vetteguy0483's Avatar
Default Changing Starter
Does anyone have a "how to" on changing the starter?
vetteguy0483 is offline   Reply With Quote
Old 03-26-2008, 09:44 AM   #2
Plasticfan
CF Senior Member
Plasticfan's Avatar
I did a quick search and didn't find any. Probably cause it's real easy.
*disconnect batt cable.
*disconnect exhaust pipe from manifolds and back by the trans.
*lay pipe on floor out of your way.
*disconnect wires
*remove two bolts and starter comes out.
Just like all the old Chevy V8's except for the pipe.
It took me about 2 hrs so you can do it in 1.
HTH
Plasticfan is offline   Reply With Quote
Old 03-26-2008, 10:18 AM   #3
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
Document ID# 642923
2002 Chevrolet Corvette
Starter Motor Replacement
Removal Procedure
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure .
2. Remove the catalytic converter. Refer to Catalytic Converter Replacement in Engine Exhaust.
3. Remove the positive battery cable nut.
4. Remove the positive battery cable terminal and the engine harness leads from the solenoid.
5. Remove the S terminal nut (2).
6. Remove the purple wire lead (1) and washer from the solenoid.
Object Number: 74063 Size: SH
Click here for detailed picture of above image.
7. Support the starter motor.
8. Remove the starter motor bolts.
9. Remove the starter motor.
Installation Procedure
1. Position the starter motor to the block.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the starter motor bolts.
Tighten
Tighten the starter motor bolts to 50 Nm (37 lb ft).
Important
Orient the purple lead wire to the 10:00 position when installing.
3. Install the starter motor S terminal washer and purple lead wire
(1).
4. Install the S terminal nut (2).
Tighten
Tighten the S terminal nut to 4 Nm (35 lb in).
Important
Orient gray and rust harness leads to the 6:00 and 7:00 position.
5. Install the gray and rust harness leads to the solenoid.
6. Install the positive battery cable terminal to the solenoid.
7. Install the positive battery cable nut.
Tighten
Tighten the positive battery cable nut to 8 Nm (71 lb in).
8. Install the catalytic converter. Refer to Catalytic Converter Replacement in Engine Exhaust.
9. Connect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure .
lucky131969 is offline   Reply With Quote
Old 03-26-2008, 07:07 PM   #4
vetteguy0483
CF Senior Member
ok thanks. i was told that you have to remove the exhaust manifold and i wasnt looking forward to that
Reload this Page Changing Starter
Tags
1986, 2000, 2007, 77, asrarter, c5, cahnge, change, changing, corvett, corvette, ls1, removing, soliond, starter, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
