LG Street Header: NEED HELP! Very frustrated! Pass Side Won't go in!
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
Can someone please give me good instructions and pictures if at all possible. My LG street passenger side will not for anything go in! It keeps jamming between the AC lines and the underside of the car. I managed to get it to clear the starter but that was it....and then on top of it.....the damn air pipe (which I don't think you can bend at all) is always in the way and wedging itself between the header.
Can someone please assist! I worked on this problem for 3 hours today with no luck.
The only problem I remember having was getting the bracket on the header that bolts to the bottom of the tranny (never did get it to line up with the bolt holes) passed the starter. I'm pretty sure I took my valve cover off too, not sure that I needed to. Other than that, it took about 30 seconds to drop it in. Good luck
How high do you have your car. At least with the AR's, you had to get high enough to basically stand the header upright and twist. I also had to remove the starter wires and pull the starter to get it in, but that was because I didn't have help and it was caught up on some other electrical wires. Also had to remove a ground wire that was attached to the block(?).
The air tube is not flexible, but you should be able to move it around enough to get it out of the way. I basically pulled mine up and hooked it on one of the coil packs, and it stayed. Mine's also an 02.
What you should do is take a break, have a beer or two, and go back to it tomorrow. Nothing ever good comes when you get frustrated (my broken right toe will attest that kicking things that aren't working is not the solution. )
NCM Bash 2008-2018
i agree
So yeh tomorrow gonna go at it again. I have the car up pretty high 21 inches to be exact. There is no way with that height will it go in from the bottom. I will have to try again from the top. If it won't go in from the top I will have to try to jack it up higher but Iam already using my jack and 2 4x4 blocks of wood to get it to this height. So I dunno...have to see what I can do.
Only other thing I have heard is to try to jack the motor up a little to see if that helps.
Its weird, I got passed all the normal bad places that would hang it up. I cleared the starter and nothing below is obstructing it, except what looks like the cars undercarriage. I think however it will go if I forced it. Iam concerned however how tight a fit it is on the ac lines though. It is really tight. That and I have only been able to move my air tube about 1inch up, anymore then that and Iam getting nervous it will break. Currently right now that leaves the airtube wedged in between the header and the block.
LG Install
Yes the pass side goes in from on top. If air tube is in the way remove - it is attached by a 13 mm bolt behind on the drivers side head. I have taken off the valve cover for some xtra wiggle room. The starter has to be moved out of the way of the positioning tab on the header. Good luck - just take time they do go in.
I don't know if you have seen these to install how to's, so I will post them for you.Good luck, hope they help.
http://www.cajundude.com/longtubes2.htm
http://www.ls1howto.com/index.php?ar...00d5d67b42fec3
Did you get the instruction sheet from LG ? Also they told me if you go in from the bottom you need try pry the motor over a little. That's how they do it in their shop. It also sounds like you need to get your car higher to go in from the bottom.
lg install
I installed mine about six weeks ago. I did both sides from the bottom. The pass side was harder than the drive side. The trick for me was to get the car very high. My instruction sheet called for at least 2 feet so I had to jack in 3 stages and got it up to 26 inches. And it really looks high like that but the header went right in after moving the starter wiring. I did not remove the starter itself or either valve cover. I made shoring to set the jack and stands on to get it that high. This is what worked for me. Good luck.
Put LG streets on last summer. Passenger side I did from the top with coils removed. Just wiggled past the ac lines. Drivers side was a bit tricky but go in from the bottom. A twist and a push and it went up and in (like FnM ) the job can be a bear but you can do it. I had my 02 24'' off the ground. Good luck!
