Here are all the contacts cleaned up:
I used a mechanical pencil with sand paper glued to the eraser to clean the fixed contacts. The eraser was trimmed down to fit the recess in the switch housing:
Once the contacts are cleaned up, bend the contact arms so that they apply more tension on the fixed contacts. It doesn't need too much bending:
Once you apply more tension to the contacts, you will need to be careful when reinserting the arms back into the switch. The movable contact pads will tend to hang up on the fixed contacts. Assist them over the fixed contacts. I used a hooked paper clip to raise the arm over the fixed contact.
I used two flat blade screwdrivers to apply force to contacts A & B inside the switch contact well to keep the contact arms forced down on the fixed contacts to prevent them from popping out of place while installing the green cap. Once the contacts are in place,
snap the green cap back on the switch. Check the CLEANED contacts with an ohm meter. They should read very close to ZERO OHMS.
Please feel free to ask me any questions that you have. I feel I'm a IGNITION SWITCH expert now!
Marks old NASTY broken switch is as good as new!!!!!!!!!!
* NOTE!!!!! UP_DATED 10 Sep 2012:
Some DO's and DONT's
1. It is NOT necessary to disassemble the lower portion of the switch!! There is NOTHING in there electrical related!
2. Electrical contact cleaning: Deeply pitted contacts can be cleaned using 400 Wet & Dry paper but should be polished with finer & finer grits to a highly polished surface 400, 600, 800 1000 grit wet & dry paper and cleaned with alcohol when done polishing. If there not deeply pitted start with 800 grit. It is strongly recommended to assemble the switch contact arms and place sand paper between the contacts. Apply force on the movable contact arm and pull the sand paper THRU the contacts. This will seat the upper and lower contacts and put a larger contact patch on the contacts. The larger the contact patch on the switch contacts allow the contacts to pass higher currents before over heating!
3. Measure the repaired contacts with an OHM METER before reassembly!! If you dont have ZERO ohms, figure out why and fix it! Make sure that the OHM Meter is on the ohms X1 Scale or in auto mode and your really are reading ONE OHM or less. Cycle the switch several times and make sure you get constant good resistance readings!
4. When you insert the key into the switch lock tumbler, the end of the key pushes on the small button on the center of the tumbler well. Its important that you test the operation of that switch as it tells the BCM when the key is in or out of the switch/tumbler.
5. On the front of the tumbler is a small sensor. Inside that sensor are two small silver coated contacts. Those contacts read the resistor pellet embeded in your key. Measure the pellet in your key. insert the key into the sensor and measure the output of the sensor with the key in it. The two readings should match. If they dont the sensor contacts are dirty or damaged.
BC
Heres the procedure for removing the ignition switch from the dash:
Ignition Switch Replacement
Removal Procedure
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable.
Apply the parking brake.
Remove the console. Refer to Compartment Replacement - Instrument Panel (I/P) .
Removal Procedure
Open the instrument panel (I/P) passenger compartment door.
Disconnect the electrical connector from the I/P compartment lamp switch.
Remove the trim plugs from the bottom of the compartment door. Reach behind the compartment door and push the plugs out. Use a suitable flat bladed tool on the front side to remove the plugs, if necessary.
Remove the lower retaining bolts from the I/P compartment.
Remove the side and upper retaining screws from the I/P compartment.
Slowly pull the I/P compartment just enough to disconnect the wiring harness connector from the inflatable restraint module switch.
Remove the I/P compartment.
Installation Procedure
Connect the wiring harness connector to the inflatable restraint I/P module switch connector.
Install the I/P compartment.
Loosely install the screw which retains the side of the I/P compartment, in order to align the nut on the passenger SIR bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the upper retaining screw to the I/P compartment. Tighten
Tighten the retaining screw to 1.9 N·m (17 lb in).
Install the lower retaining bolts to the I/P compartment. Tighten
Tighten the retaining bolts to 12 N·m (106 lb in).
Align and hold the I/P compartment to the I/P, then install the side retaining screw to the I/P compartment. Tighten
Install the trim plugs to the I/P compartment door.
Connect the electrical connector to the I/P compartment lamp switch.
Close the I/P passenger compartment door.
Remove the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory .
Removal Procedure
Apply the parking brake for additional clearance around the parking brake lever.
Shift the transmission into SECOND (A/T), or FOURTH (M/T).
Remove the console. Refer to Console Replacement .
Grasp the shift control boot (M/T) and apply light pressure in toward the shift control lever, to begin to release the shift boot retaining tabs from the instrument panel (IP) accessory trim plate.
Using light pressure, continue to release the remaining boot retaining tabs, then lift the boot away from the trim plate.
Open the cigar lighter door and remove the ashtray.
Remove the IP accessory trim plate grille. Pry gently at the side edge with a flat-bladed screwdriver to release the tab.
Remove the accessory trim plate retaining screws next to the cigar lighter and behind the ashtray.
Remove the accessory trim plate retaining screw in the grille opening.
Grasp the sides of the accessory trim plate near the curve at the base.
Pull the trim plate rearward to release the locking tabs. Lift the rear of the trim plate to clear the driveline tunnel studs.
Disconnect the electrical connector from the cigar lighter.
Rotate the shift control boot (M/T) and reposition one end down into the shifter opening in the trim plate.
Lift the accessory trim plate over the shifter (and shift control boot, M/T), and remove the trim plate.
Lower the IP accessory trim plate over the shifter and under the parking brake lever. Position the shift control boot (M/T) as during removal and insert the boot up through the shifter opening in the accessory trim plate.
Connect the electrical connector to the cigar lighter.
Install the trim plate into position. Align the locator tabs and the locking tabs to the slots.
Begin to install the upper locator tabs and the upper locking tabs, then work downward to install the remaining tabs. Install the rear of the trim plate onto the driveline tunnel studs.
Notice
Install the accessory trim plate retaining screws. Tighten
Tighten the IP accessory trim plate retaining screw next to cigar lighter to 1.9 N·m (17 lb in).
Tighten the IP accessory trim plate retaining screw behind ashtray to 1.9 N·m (17 lb in).
Tighten the IP accessory trim plate retaining screw in grille opening to 1.9 N·m (17 lb in).
Install the accessory trim plate grille. Position the grille, then push to secure.
Install the ashtray.
Install the console. Refer to Console Replacement .
Align the shift control boot to the IP accessory trim plate opening, then press to lock the boot retaining tabs.
Adjust the shape of the boot for appearance, if necessary.
Shift the transmission into PARK (A/T), or REVERSE (M/T).
Release the parking brake.
Remove the driver knee bolster trim panel. Refer to Trim Panel Replacement - Knee Bolster .
Removal Procedure
Remove the fog lamp, rear compartment lid release switch.
Pry carefully at the lower edge of the switch to release the locking tab.
Disconnect the electrical connector from the switch.
Remove the driver knee bolster trim panel retaining screw behind the fog lamp, rear compartment lid release switch.
Remove the driver knee bolster trim panel lower retaining screws.
Grasp the trim panel at the side edges.
Pull firmly rearward to release the locking tabs.
Disconnect the electrical connector from the inside air temperature sensor, if equipped.
Remove the trim panel.
Connect the electrical connector to the inside air temperature sensor, if equipped.
Insert the electrical connector for the fog lamp, rear compartment lid release switch through the opening in the trim panel.
Install the driver knee bolster trim panel.
If equipped, insert the inside air temperature sensor wire down into the driver knee bolster bracket to avoid pinching the wire.
Align the locking tabs to the slots.
Push the trim panel to secure.
Loosely install the screws retaining the bottom of the driver knee bolster trim panel, in order to align the nuts on the knee bolster bracket.
Notice
Install the remaining driver knee bolster trim panel retaining screw. Tighten
Tighten the driver knee bolster trim panel retaining screw behind fog lamp, rear compartment lid release switch to 1.8 N·m (16 lb in).
Tighten the driver knee bolster trim panel lower retaining screws to 1.8 N·m (16 lb in).
Install the fog lamp, rear compartment lid release switch.
Connect the electrical connector to the switch.
Align the switch, then push to secure.
Install the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory .
Remove the ignition switch lock cylinder electrical connector from the retaining tab on the side of the ignition switch.
Disconnect the lock cylinder electrical connector.
Important
Take note of the way in which the ignition switch lock cylinder wire is wrapped around the base of the ignition switch bezel.
Remove the ignition switch bezel. Carefully pull to unsnap.
Remove the hazard warning switch wiring harness from the ignition switch retainer.
Disconnect the ignition switch electrical connectors.
Disconnect the park/lock cable (A/T) from the ignition switch.
Insert the key into the ignition switch, then turn the ignition to ON.
Using a flat bladed screwdriver or other suitable tool, depress the park/lock cable retaining tab (located on the underside of the switch near the base of the cable).
Pull to remove the cable.
Remove the ignition switch retaining bolts.
Remove the ignition switch.
Install the ignition switch into position on the ignition switch housing bracket.
Notice
Install the ignition switch retaining bolts. Tighten
Tighten the ignition switch retaining bolts to 5.5 N·m (49 lb in).
Install the park/lock cable (A/T) to the ignition switch (still in the ON position). Push to secure the cable retaining tab.
Connect the ignition switch electrical connections.
Install the hazard warning switch wiring harness to the ignition switch retainer.
Install the ignition switch bezel to the switch.
Wrap the ignition switch lock cylinder wire around the base of the ignition switch bezel, as noted during removal.
Align the bezel slots to the lock cylinder pins, then push to secure.
Connect the lock cylinder electrical connector.
Install the lock cylinder electrical connector to the retaining tab on the side of the ignition switch.
Install the driver knee bolster trim panel. Refer to Trim Panel Replacement - Knee Bolster .
Install the console. Refer to Compartment Replacement - Instrument Panel (I/P) .
Connect the negative battery cable. Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
Program the transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry.
If you "THINK" you have an ignition switch issue, you can use a volt meter and measure the output of the ignition switch.
There are TWO voltages that power the critical modules in our cars. One is "HOT AT ALL TIMES" and the other is "HOT in ACC and ON". When you turn the ignition switch to ON, you can read the fuses listed below and you should see exactly what the battery puts out. If the electrical contacts inside the switch are burnt, there will be resistance in the circuit and the voltage output of the switch will be lower or even zero.
On top of the fuses are two small holes that you can insert pin point meter leads into and read that fuse terminal. MAKE SURE to read both holes. If the fuse happens to be blown, only the battery side will have voltage on it.
Heres another troubleshooting tip: If you read across the fuse; If it good, you should read ZERO VOLTS!
If its bad, you will read BATTERY VOLTAGE.
Heres the schematic for the START /Crank side of the switch:
Heres the schematic for the IPC and the voltage that you see on the IPC Volt Meter:
Here are the fuses powered by the "HOT in ACC and ON". part of the switch:
Ok,,,here are the fuses that your going to check:
Under Hood Fuse Center
ENG ING1 FUSE# 19
INJR 2 FUSE# 18
THROTCONT FUSE# 17
INJR 1 FUSE# 22
PCM FUSE# 16
F/PMP FUSE# 13
Instrument Panel Fuse block
BTSI BU Fuse# 21
BCM 13 Fuse# 22
IPC Fuse# 19
Check the VOLTAGE on these fuses when the ignition is in the ON position. There should be battery voltage on these fuses.
Another ignition switch troubleshooting aid is; If the engine will run when you HOLD the ignition switch to the CRANK position but dies when you release the key, the switch could be at fault.
SOME
UP DATED Switch repair info Sep 2011:
Some additional guidance on the ignition switch repair.
Remember to re-arch the movable switch contacts so that they have better contact with the fixed contact point. Once there re-arched, you will need to use a hook (I used a bent paper clip) to ASSIST the arms over the FIXED contacts when your sliding them back into place!
Once the switch movable contact arms are in place, insert a piece of 600 grit wet and dry paper between the closed contacts and with a small pair of needle nose pliers or a pair of tweezers (I use a small pair of curved hemostats),, Move the sand paper between the contacts while applying some pressure on top of the movable arm. Switch to 1000 grit and polish the contacts. Clean the contacts with alcohol.
What your doing is making the CONTACT AREA of that single switch larger than it was. That will give the contact more current carrying ability and better contact. Do that to each of the FIVE switches....
REMEMBER!! Measure the resistance of EACH of the newly cleaned, re-arched, sanded and polished and cleaned contacts to make sure you have very very close to ZERO ohms resistance when the contacts are shut! If you have resistance, go back and CLEAN the contacts with alcohol again
Here are a FEW UPDATES that have been added as we refine this repair process:
Recommned that you obtain some 600 grit wet and dry sand paper. Cut a strip about 6" long X 3/4" wide. Fold it in half so that you have sand paper on both sides. Work the sand paper in between all the contacts on one side of the switch. Pull and push the sand paper between the stationary contacts and movable contact arms. Doing this will lap in a bigger contact area between the two contacts thus allowing the switch to carry a bigger current load without heating up. When you are done lapping the contacts on one side, lap the other side.
NOTE! Make sure that you recheck the contact pressure on the contach arms to insure that they are still making firm contact. Clean the contacts and recheck the resistance of each switch.
NOTE! The Electrical connectors with FEMALE PINS that pulg into the Ignition Switch can spread and male poor connection with the male pins inside the switch. Check the female pins inside the two power connectors:
Once you sand the burned marks off the bent female pins, rebend them back so that the tong makes better contact with the male pins inside the switch. There are TWO damaged large pins in the black plug and one on the white plug.
Bill
Update 24 May 13
I have to admit that; just because the ignition switch contacts look burnt, they still could be fine. The problem occurs when the contacts start building resistance from the carbon, poor contact continuity and burnt contacts.
That excessive resistance causes the 12 VDC battery voltage supplied to the switch and controlled by those contacts to be something LESS than full battery voltage. If the switch is marginally defective, it may work one ignition sequence and fail horribly the next. Please check the ignition switch resistance AND electrical output after cycling it several times.
Most of the problems with our ignition switches are, the contacts do not close perfectly parallel and after thousands of OPEN/SHUT cycles, the contact arms heat up and loose tension. That’s when the resistance starts building and the switch contacts generate excessive heat and degraded voltage outputs.
Before any ignition switch is rebuilt/repaired, you should measure the closed contacts with an OHM Meter and see what you have resistance wise. Measuring all the contacts requires cycling the switch thru all of its available positions. Write down the resistance value before repair and then again after repair.
When you repair/rebuild the switch, re-arch the movable contact arms so that they shut with more pressure.
One of the reasons that the contacts get hot is, some circuits draw a moderate amounts of current. If the contacts don’t close perfectly parallel, there is only a very small contact point for the current to flow thru. That causes heat and excessive arching when the contacts shut.
Im going to reassemble a switch and slide some wet and dry sand paper between the closed contacts and work the paper between the contacts to LAP the contacts so that they have a larger contact point
NOTE! Anytime you clean/sand or file any electrical contact, you should finish the surface as smooth as you can and before finial reassembly, clean the contacts with isopropyl alcohol so that there is no grease or grit between the contacts.
As always, CHECK THE RESISTANCE of each contact in the switch (you have to cycle it thru all it positions) and make sure that it is not excessive. When you re-arch the movable arms, if you are TOO AGGRESSIVE, the switch contacts will never open when the arm is pushed open and that will cause an ignition circuit to remain ON when its suppose to be OFF. That will cause excessive battery current draw in the sleep mode and KILL the battery in short order.
Something else that needs to be examined is the female pins in the ignition switch connector. If they are spread and make poor contact, they also can cause lower ignition switch output voltages. I have seen female pin contacts so loose that they heat up and melt the connector causing ignition switch failure on all outputs for that 12 VDC circuit.
Look at the picture provided. Two of the contacts in the black connector (the two on the inboard contacts) are spread apart and have signs of electrical arcing and carbon. They need to be cleaned and the tong needs to be bent so that it makes better contact with the male pin inside the switch
I will add this to my Ignition Switch post.
Bill
