2002 AC Problems
Old 10-03-2021, 01:59 PM
drdrwood
drdrwood's Avatar
Default 2002 AC Problems
I have seen this problem posted many times. My 2002 began blowing hot air on driver’s side, cold on passenger side. I replaced actuator with a Dorman, did not help, tried resetting it, no luck. Made sure Freon was charged, it was. Checked vacuum line, good shape. When I change mode on climate control it changes from dash to floor to defrost and air comes out of the correct vents, changing the mode works. However even on the defrost the drivers side of the defrost vent is warm and the passenger side is cold. Any suggestions would be appreciated.
Old 10-03-2021, 02:42 PM
C5 Diag
Moderator, Tech Contributor
Support Corvetteforum!
C5 Diag's Avatar
Received 2,116 Likes on 1,683 Posts
How did you check that the Freon was charged ??
Old 10-03-2021, 03:55 PM
drdrwood
drdrwood's Avatar
I bought a recharge kit with Freon at autoZone with gauge on it.
Old 10-03-2021, 04:06 PM
C5 Diag
C5 Diag's Avatar
Those recharge kits aren’t the best way to check your Freon or to know if you have the correct amount…suggest you take the car to an AC specialist and let them recover the Freon and then put a vacuum on it to check for leaks and then let them properly put the correct amount of Freon in it !!
Old 10-03-2021, 06:52 PM
drdrwood
drdrwood's Avatar
Thanks, I will do that. I hope this fixes it. I was sure it was an actuator problem.
Old 10-04-2021, 02:03 PM
VetteMed
VetteMed's Avatar
Classic failure mode when low on refrigerant due to the path that refrigerant takes through the dual zone evaporator core in the C5. The passenger side receives refrigerant first from the orifice tube where it goes from high pressure to low pressure, but with a low charge the system doesn't have the capacity to absorb enough heat to allow the driver's side airflow to feel cool.
Old 11-15-2023, 08:18 PM
drdrwood
drdrwood's Avatar
It was checked by two shops.
Old 11-15-2023, 09:07 PM
redzg
redzg's Avatar
Same problem 2 years later?
To 2002 AC Problems
Quick Reply: 2002 AC Problems
