Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2008, 12:10 PM   #1
71vetteinva
CF Senior Member
Default What is the age of my AC Delco Battery?
I just bought my 2000 used and I'm going through all the normal checks. I discovered quickly that the coolant probably hadn't been changed...ever by the looks of it! I addressed that issue yesterday.
I suspect the battery might also be eight years old. If so, then I might replace it in the next few months. How do I tell the age of an AC Delco Battery?
Mine is marked :
AC Delco
78-6YR
Serial Number: 833571
There is also a P followed by a stamp that reads 056N
Edit: Nevermind. I found the answer. If anyone is interested. Looks like my battery was made in May of 2006.
How do I read the warranty date code on my battery?
The warranty date code is located on the top label of the battery. The first character is either a P or S. The next two digits determine the month, the third digit is year and the fourth digit indicates the manufacturing plant. For example, P 094N means the battery was made in September 2004 in the New Brunswick factory.
71vetteinva is offline   Reply With Quote
Old 11-18-2009, 09:28 AM   #2
killain
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Oldtimer
Support Corvetteforum!
killain's Avatar
Send a message via AIM to killain
Default Deciphering codes on ac delco battery
Hay thanks for the info. I was trying to figure out my batterys point of life, and it's got a number on the label of ACD 75/60 and below that is the # S116P so that means the battery is a 5 year battery and it was made on November of 2006 at the 'P' plant Now I'm wondering if I should muster through another winter with it or get a new one. It was in my car( My C-4) when I got it. What do you think? Thank you !
killain is offline   Reply With Quote
Old 11-18-2009, 11:52 AM   #3
2079
CF Senior Member
2079's Avatar
Quote:
At the price of a battery I personnaly never try to outlast them.The first time you get standed you pay for it just in wasted time and ......Its your call but do the math of the cost per year for reliablity.
2079 is offline   Reply With Quote
Old 11-19-2009, 10:57 AM   #4
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14
Quicksilver Vert 01's Avatar
5 year battery and it was made on November of 2006 at the 'P' plant Now I'm wondering if I should muster through another winter with it or get a new one. What do you think?
Since it's just barely 3 years old, I would say that it's still good for another 2-3 years of reliable service.
Quicksilver Vert 01 is offline   Reply With Quote
Old 11-19-2009, 01:36 PM   #5
DeeGee
DeeGee's Avatar
Dave Gledhill David Gledhill
And most importantly the new batteries don't leak
DeeGee is offline   Reply With Quote
Old 10-21-2012, 07:22 PM   #6
jerrys vette
CF Member
Thanks for all info---jerry
jerrys vette is offline   Reply With Quote
Old 10-21-2012, 08:48 PM   #7
Got uid0
CF Senior Member
Got uid0's Avatar
Quote:
Not True at all
Well known issue around 98-01 stock ac delco batteries that the positive post would come off on the battery causing a leak.
Got uid0 is offline   Reply With Quote
Old 10-22-2012, 12:23 PM   #8
corvettebob1
CF Senior Member
corvettebob1's Avatar
Not True at all
"Well known issue around 98-01 stock ac delco batteries that the positive post would come off on the battery causing a leak."
But then this is almost 2013, just how many of those 12 year old batteries are still in service?
corvettebob1 is offline   Reply With Quote
Old 10-22-2012, 10:00 PM   #9
Got uid0
CF Senior Member
Got uid0's Avatar
Quote:
Not True at all
point being stuff happens
Old 10-23-2012, 12:09 PM   #10
vetteman138
Junior Member
Default 98 Battery
I have a 98 and my battery lasted 8 years before I put a new AC Delco in. This battery is still in and working fine. I never used a battery tender on them.
vetteman138 is offline   Reply With Quote
Old 10-23-2012, 12:25 PM   #11
LoneStarFRC
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
LoneStarFRC's Avatar
Location: Perseverance: The courage to ignore the obvious wisdom of turning back.
That was a design flaw particular to those particular batteries used in those particular years. Those things are long gone.
LoneStarFRC is offline   Reply With Quote
Old 11-16-2012, 07:37 PM   #12
jerrys vette
CF Member
Just pulled battery out of my 2004. It is a ac delco. I think it is original.
Here is all the info I could find.
cat# 0925
590 cca
86-6yr
Prick punched on top were
4021f54
Stamped on side were
4d16by1e
No other ident can be found----looks goofy to me, help---thanks---
I will be replacing battery anyway. Curiosity getting to me.
Old 11-17-2012, 09:08 AM   #13
leadfoot4
CF Senior Member
leadfoot4's Avatar
Quote:
I store my car during the winter, and I know while it's good for the car, it's an "iffy" deal for the battery. I do put a charger on it for 10-20 minutes each week, usually when I've got the snowblower out to clear the driveway, but still, after 4 years, I usually wind up replacing it....
leadfoot4 is offline   Reply With Quote
Old 11-17-2012, 01:41 PM   #14
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill Curlee's Avatar
Quote:
You my friend need to run right down to the Minimart and buy some LOTO tickets. I too rolled the dice on my 98 Coupe battery and won but,,,,, After seeing what happens when they FAIL and leak,,, I would installed another battery. SOON!!!
I believe that the LEAKAGE issue has to do with if the POS and or NEG terminmal was abuse. Some were just plain outright defective and leaked right thru the bolt hole.
You have been warned.
On a positive note,, the battery in my 97 F150 lasted 12 years and was in the truck working fine when I sold it.
BC
Bill Curlee is offline   Reply With Quote
Old 11-17-2012, 03:36 PM   #15
Quicksilver Vert 01
Didn't anyone notice that this thread is nearly 5 years old?
Old 11-17-2012, 04:25 PM   #16
The Big Guy
CF Senior Member
St. Jude Donor '12-'13-'14
If you are a gambler, trust A/C Delco batterys. If you have had the problem of their leakage you would definetly have the intelligence to use another brand. There are several other gel battery manufactueres. Been there did that.
A word to the wise is sufficient.
The Big Guy is offline   Reply With Quote
Old 11-18-2012, 02:10 PM   #17
leadfoot4
CF Senior Member
leadfoot4's Avatar
Quote:
I guess not...It floated to the top, and we all jumped on it.
Reload this Page What is the age of my AC Delco Battery?
Tags
786yr, ac, acdelco, age, batterie, battery, car, check, code, codes, date, delco, number, serial, warranty
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Which year of the C5 is the BEST? jacobus20 C5 General 50 10-05-2004 02:59 PM
Ken's Weekly News - 7/18/03 - New Rebates, Corsa Overstock Sale! Ken Fichtner Ken's Newsletters 21 08-19-2003 09:26 AM
Ken's Weekly Newsletter-Friday, June 13-2004 Corvette Prices Here! Ken Fichtner Ken's Newsletters 9 06-24-2003 09:42 AM
Ken's Weekly Newsletter - May 2, 2003 - WOW! Lots of NEW news! Ken Fichtner Ken's Newsletters 35 05-12-2003 05:04 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
