Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-23-2008, 05:30 PM   #1
jaxvet
CF Senior Member
jaxvet's Avatar
Default High Mileage C5's
My 98 was totaled in a road rage incident & I am looking at a 2000 w/hi mileage with 2 owners, & serviced by both at same dealer where it was purchased. It is an A4 coupe w/most options. Has been serviced regularly & has clean carfax.
What to watch out for on hi mile vettes? What should I be looking for as far as problems go? I'm on fixed income & lower price would allow me to do some mod's to car to personalize it. Any info will be appreciated.
jaxvet is offline   Reply With Quote
Old 02-23-2008, 05:38 PM   #2
timemender
CF Senior Member
timemender's Avatar
Below is a link to an interesting thread on the durability of the C5 Corvette. Note the post by Evil-Twin a retired Corvette engineer.
What do you consider high mileage for a Corvette? Sounds like you found a well cared for Corvette.
http://forums.corvetteforum.com/show...1902695&page=1
timemender is offline   Reply With Quote
Old 02-23-2008, 06:09 PM   #3
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
If they are cared for properly and not abused, they can have a very long life. As already asked, what do you consider high mileage?
__________________
1999 Coupe, Black/ Black, MM6
2007 Coupe, Montery Red, Cashmere, MZ6, 3LT, Z51 loaded
dgrant3830 is offline   Reply With Quote
Old 02-23-2008, 06:24 PM   #4
C5Pat
CF Senior Member
C5Pat's Avatar
Mine had 72k on it when I bought it. It has given me no problems so far other than what I think is a rear axel seal leak (very small). Another way to look at it is any troubles or bugs it may have had are probably fixed!! Good Luck ,..........Enjoy
C5Pat is offline   Reply With Quote
Old 02-23-2008, 07:05 PM   #5
rcknusa
CF Senior Member
rcknusa's Avatar
I have a 2000 coupe a4 with 121K on it and drive it everyday. My problems have been oil pressure sender unit, head light issuses all the time, and key fob/transmitter stuff, wind noise at window, and the road noise that all have. If I wasn't so picky about things I would say that for the last 70K that I have owned it (3yrs) it has done very well.
__________________
Support our troops around the world!!
rcknusa is offline   Reply With Quote
Old 02-23-2008, 09:28 PM   #6
vettekidc5
CF Senior Member
vettekidc5's Avatar
I have 122K on a 99 M6 Z51. Raced on pretty hard Since 90k by me
Original clutch and slave. Car had no other mechanical issues Ie headlights and etc untill about 3 weeks ago..
My motor Spun a rod bearing #5 Cylinder. LS1's are known for rod knocking and Spun rod bearings If youll research on LS1tech.com
From my research theres several theories, The earlier LS1 oil pumps, and ALL year stock LS1 rod bolts. Im not terribly mad this happened as this has happened to low mileage LS1's in camaros, firebirds gto's etc..
If you can spare the time or cash I definately would upgrade the oil pump and Rodbolts if nothing else.
vettekidc5 is offline   Reply With Quote
Old 02-23-2008, 11:42 PM   #7
jaxvet
CF Senior Member
jaxvet's Avatar
I found info on a 2000 coupe w/125K, it's the color & color interior I want & the options I would like. I've already run a carfax report & it shows normal maintenance & no reported accidents or bodywork, 2 owners, bought new at a local dealer & serviced there by both owners & it passed emmissions in Nov 2007 & trans was flushed in May 2007. My 98 had 60K when I bought it & never had any probs except for oil sensor, which I did a relocate on. No electrical issues or anything & it had a little over 80K when it was totaled. I have friends that have less than 40K on newer vettes & have already had the gas sending units go out & wheel bearings. So is it just kind of "the luck of the draw"?
Old 02-24-2008, 01:13 AM   #8
dgrant3830
dgrant3830's Avatar
Well 125K is up there a bit but again, if the price is right and the maintenance was done correctly and everything still works normally, then you should be good. Price will be a consideration. If its a MM6 then it'll need a clutch if not done already. Look for abnormal tire wear therefore a possible alignment needed. Check the fluids, all of them including the differential. By the way, I'm the one with 305K on mine and still running strong. I do have to run 10W-30 these days instead of the 5W-30, but thats it.
Old 02-24-2008, 01:47 AM   #9
jaxvet
CF Senior Member
jaxvet's Avatar
Quote:
Thanks for the info, the one I'm thinking about is an A4 & has already had trans flushed & radiator & had a 4 wheel align last fall at a dealer & thnx to others for the informative links.
Old 02-24-2008, 04:54 AM   #10
racetchr
CF Senior Member
racetchr's Avatar
My '00 has 229k and still on the original water pump, starter, a/c, power steering, and front wheel hubs/bearings. Outside of the normal "little" stuff, like batteries and fuel filters, etc. these cars can be bulletproof if maintained. Have always used Mobil 1, changed trans and diff fluid regularly (Redline) and use magnetic plugs on oil/tranny/diff to keep impurities out of the fluids.
racetchr is offline   Reply With Quote
Old 02-24-2008, 08:24 AM   #11
rws.1
CF Senior Member
rws.1's Avatar
120K on my wife's '01...
I consider it just broken in.
We have had a headlight motor issue, oil pressure sensor, dim A/C display, door control module issue.
Any other work has been normal maintenance.. or mods.
I just asked my wife if she wanted a high gas mileage hybrid or even an electric car for summer in city commuting.... her response.... what's wrong with my Vert?
rws.1 is offline   Reply With Quote
Old 02-24-2008, 08:34 AM   #12
racetchr
CF Senior Member
racetchr's Avatar
I'd like to hear the road rage story.....
Reload this Page High Mileage C5's
Tags
buying, c5, cars, considered, corvette, corvettes, engine, good, high, highest, ls1, mileage, mileagecorvette, miles, problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
High mileage C5 values, selling prices Gary K C5 General 19 07-20-2005 05:46 PM
High Mileage C5 Concerns 67tripwr C5 General 25 04-10-2005 10:22 PM
Hazards of Buying High Milage C5's??? mbeeman350 C5 General 18 02-12-2005 10:19 PM
C5's are dropping in value . . . Hmmmm? 74-Roadster C3 Tech/Performance 16 06-15-2003 12:42 PM
Any chance i could find a super high mileage Z06 for around $27k??? Weedo C5 Z06 Discussion 17 04-29-2003 12:05 AM
High Mileage C5 Maintenance Experiences Arkay C5 Tech 10 07-05-2002 11:22 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
