Broken seat bracket, how to fix?
So I don't know how it happened, but a main bracket for supporting my driver seat broke. This one is on the back on the left side (as if you were sitting in the seat). In one picture I have the broken part sort of sitting on top of the other half of it, which is still riveted to the rail. I have a machinist friend that can make me a new one of these, but I was wondering if there is an easier answer. If I weld it, its going to brake again because its some kind of crapy cast aluminum or zinc part, so thats really not a good option.
Any ideas?
Any ideas?
I had the same problem but both sides were broken I checked with the dealer and found out you cant buy just the broken part would have to buy the whole seat track I think it was about $750.00 so I made my own made the flange part and welded a steel sleave to it has worked for about 3 months now. If I can help let me know. Bassspring
1 Post
Good luck.
The sleave sounds like a good idea. I was guessing I'd have to make my own part, which isn't a big deal. I was sort of just wondering how common this was. If anything, seat brackets are usually rock solid parts for safety reasons (duh). I wouldn't think this would be something I'd have to worry about.
I tried to replace my bracket, but couldn't becaus the deal that moves the seat up and down was broke and I couldn't get at any of the nuts to dis assemble the bottom of the seat
You're pretty much screwed. It's cheap metal. Unless you can weld and fabricate your own bar, it's time do check ebay and on here for a new seat frame.
I've seen them for as low as $50 to a high of $300.
