Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-16-2008, 01:50 PM   #1
97bossvette
Junior Member
Default DIY Auto Transmission Fluid Replacement?
I am looking for a DIY transmission fluid replacement on a C5, i am really looking for pictures on where the full plug is or where the sending unit is, thanks
97bossvette is offline   Reply With Quote
Old 02-16-2008, 02:22 PM   #2
_Will_
CF Senior Member
_Will_'s Avatar
Location: Somewhere between mild insanity and complete psychosis
profile.php?id=100003508426727 _Will_Bridges_ williamsbridges Boosted C5 Boosted_C5
Have fun with that, definitely not an easy DIY unless you have a lift.
The filler/cap is either on or near the tranny (never did it myself, just watched) so jack-stands will be a PITA. I can't remember the exact procedure, but after you fill it to a certain point you have to start the car and let it run while you top it off.
_Will_ is offline   Reply With Quote
Old 02-16-2008, 05:17 PM   #3
99 vett babycar
CF Senior Member
99 vett babycar's Avatar
you can not flush all the trani fluid out of your trani without a flushing machine like the GM dealerships and some trani shops have. Best you can drain out yourself is about 30%.
99 vett babycar is offline   Reply With Quote
Old 02-16-2008, 05:21 PM   #4
buoniconti81
CF Senior Member
buoniconti81's Avatar
Send a message via AIM to buoniconti81
invest in a drill pump..... then stick the hose into the hole....
buoniconti81 is offline   Reply With Quote
Old 02-16-2008, 05:21 PM   #5
buoniconti81
CF Senior Member
home depot or lowes sell drill pumps for like 10 bucks...
Old 02-16-2008, 08:39 PM   #6
middlebrookgt
CF Senior Member
Support Corvetteforum!
middlebrookgt's Avatar
Fill plug is on driver's side of trans pan. Full is when fluid comes out the hole with the engine running and trans in Park.
middlebrookgt is offline   Reply With Quote
Old 02-16-2008, 09:50 PM   #7
97bossvette
Junior Member
any pictures would help, i looked on the pan and didnt see anything other then the drain plug, thanks
Old 02-16-2008, 11:17 PM   #8
bluemaggot
CF Member
I'm doing a refill in my '99. The drain plug is the fill plug it seems. I think there should be a tube going up attached to the plug so that the level will be higher than the level at the plug in the pan. I guess there is no way to check the level unless you fill it and see how much it takes. Mine has been leaking from the back near the pan for a long time.
bluemaggot is offline   Reply With Quote
Old 02-17-2008, 01:23 AM   #9
timemender
CF Senior Member
timemender's Avatar
To check for proper automatic trans fluid level, the car must be running and be up to temperature.
It helps to have the car up on a lift, but it can be done with the car properly supported on jack stands.
Fluid will be HOT and you are working in close proximity to the HOT exhaust pipe. Wear mechanics gloves and protect your arms.
The drain plug and fill plug are one and the same.
1. With the transmission up to temperature, the car RUNNING, and the car level; shift through all the gears, finally placing the trans in “Park”.
2. Keep car running. (In “Park”)
3. Remove fill plug. Proper level hot is just at the bottom of the drain/fill hole. Add fluid to the point that it trickles out of the drain/fill hole.
4. Reinstall plug bolt.
Flushing the fluid is another matter. Yes you must have a machine to “fully” flush the fluid. Removing the pan and changing the filter will only remove a fraction of the fluid. (1/3? ½?)
If it were me, I would insist on watching the procedure to be sure they are actually doing the flush, but that’s just me.
timemender is offline   Reply With Quote
Old 02-17-2008, 11:03 AM   #10
97bossvette
Junior Member
this is doing an automatic transmission right? thanks
Old 02-17-2008, 11:09 AM   #11
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
Quote:
The pump is a good idea. Really helps to get most of the fluid out before dropping the pan for filter replacement. I advise you to get a service manual and not rely on procedures and pics online. You can follow it step by step and do the job right every time.
lucky131969 is offline   Reply With Quote
Old 02-17-2008, 11:10 AM   #12
saloonwarrior
CF Senior Member
saloonwarrior's Avatar
Yep...this is for an automatic, and like he said.....drain plug and fill plug are the same.
saloonwarrior is offline   Reply With Quote
Old 02-17-2008, 11:50 AM   #13
Patches
CF Senior Member
Patches's Avatar
Automatic Transmission Fluid/Filter Replacement
Removal Procedure
Caution
When the transmission is at operating temperatures, take necessary precautions when removing the check/fill plug, to avoid being burned by draining fluid.
Click the image to open in full size.
1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Place a drain pan under the transmission.
3. Clean any dirt from around the transmission check/fill plug.
4. Remove the transmission fluid check/fill plug and allow the fluid to drain.
5. Support the transmission oil pan.
6. Remove the transmission oil pan bolts.
7. Loosely reinstall the fluid check/fill plug.
8. Lightly tap the oil pan with a rubber mallet or pry gently in order to loosen the pan.
9. Remove the transmission oil pan.
10. Drain the remaining fluid from the oil pan.
Important
Note the position of the filter before removal to aid in installation.
11. Grasp firmly while pulling down with a twisting motion in order to remove the filter.
12. Remove the filter seal. The filter seal may be stuck in the pump, if necessary, carefully use plyers or another suitable tool to remove the seal.
13. Discard the seal.
14. Inspect the transmission fluid. Refer to Transmission Fluid Checking Procedure .
15. Inspect the transmission fluid filter. Pry the metal crimping away from the top of the filter and pull apart. The filter may contain evidence for root cause diagnosis:
o Clutch material
o Bronze slivers indicating bushing wear
o Steel particles
Important
Remove ALL traces of old gasket material from the transmission case and the oil pan gasket surfaces.
16. Clean the oil pan gasket mating surfaces, on both the transmission case and the transmission oil pan, with solvent and air dry.
Installation Procedure
Tools Required
J 36850 Transmission Assembling Lubricant (Transjel™)
1. Coat the new filter seal with a small amount of J 36850 or equivalent.
2. Install the new filter seal into the transmission case. Gently tap the seal into place using a suitable size socket.
3. Install the new oil filter into position as noted during removal.
4. Inspect the oil pan bolts and washers to determine if the conical washers are reversed.
o Reuse the oil pan bolts and washers if the conical washers are NOT reversed (1).
o Replace the oil pan bolts and washers if the conical washers are reversed (2).
5. Install the new oil pan gasket to the oil pan sealing surface.
6. Position the oil pan to the transmission case and support the oil pan.
7. Install the oil pan bolts. Tighten the transmission oil pan bolts alternately and evenly to 11 N·m (97 lb in).
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
8. Remove the transmission fluid check/fill plug.
9. Fill the transmission with DEXRON®-III automatic transmission fluid through the check/fill plug hole until fluid begins to pour out, then install the check/fill plug hand-tight.
10. Complete filling the transmission with fluid to the proper level. Refer to Automatic Transmission Fluid Level Check/Fill .
11. Inspect the oil pan gasket for leaks.
Inspection Procedure
2. Start and run the engine at idle.
3. Apply the brakes.
4. Shift the transmission into each gear for at least 2 seconds per gear.
5. Shift the transmission into NEUTRAL and continue to idle the engine for 3 minutes to stabilize the transmission fluid level.
6. After allowing the fluid level stabilization time and while still in NEUTRAL (engine still running at idle), check the transmission fluid temperature on the driver information center. Specification
Transmission fluid level temperature: 30 to 50°C (86 to 122°F)
7. If the fluid temperature is above specification, turn off the engine and allow the transmission to cool, then repeat the procedure to this point before proceeding.
8. With the engine still running at idle, loosen the check/fill plug on the LH side of the transmission oil pan.
9. Inspect the fluid level:
o Any excess fluid will drain when the check/fill plug is loosened.
o If no fluid drains, remove the check/fill plug and fill the transmission with DEXRON®-III transmission fluid until the fluid begins to overflow.
10. Install the check/fill plug. Tighten the fill plug to 30 N·m (22 lb ft).
11. Shift the transmission into PARK.
12. Release the brakes.
13. Turn off the engine.
14. Lower the vehicle.
Patches is offline   Reply With Quote
Old 02-18-2008, 11:21 AM   #14
bluemaggot
CF Member
Thanks for the information. I have one question, the fill plug seems very low on the trans to be the level the fluid is supposed to be at. It's right near the bottom of the pan, there couldn't be more than a couple quarts in there before it would be flowing over that hole it seems like.
I'll be doing the job today after having to order the filter and gasket yesterday.
Old 02-18-2008, 01:09 PM   #15
timemender
CF Senior Member
timemender's Avatar
Your observation is correct.
However - also be aware that the dip stick in an automatic transmission (on any car) DOES reach down into the pan.
Old 02-18-2008, 01:13 PM   #16
BlackZ06
CF Senior Member
BlackZ06's Avatar
@BadazzZ06
Send a message via AIM to BlackZ06
Notice that the procedure to check the fluid level specifies the engine has to be RUNNING. This ensures that the internal hydraulic system in the transmission is "primed" or "filled" with hydraulic fluid.
If you took the drain plug out of the transmission with the engine OFF you could (depending on how long the engine was off) get quite a bit of hydraulic fluid coming out of the drain plug.
BlackZ06 is offline   Reply With Quote
Old 02-18-2008, 01:17 PM   #17
timemender
CF Senior Member
timemender's Avatar
Good reminder to all reading this thread. I did highlight the word RUNNING in my "first" post, but it is easy to overlook.
Old 02-18-2008, 01:22 PM   #18
LRD VDR
CF Senior Member
LRD VDR's Avatar
This procedure really sucks specially if you have 3" exhaust like I do. I have had a flush done by a buddy at Chevy with RP a year ago but I had to add a bit cause I added a big trans cooler. I had the ever loving crap burned out of me! Then I got smart and wrapped it with exhaust wrap.
Shahram
LRD VDR is offline   Reply With Quote
Old 02-18-2008, 09:12 PM   #19
Patches
CF Senior Member
Patches's Avatar
I had to top the tranny fluid off last summer in the wife's A4 when I put in the TC and 3.42 gears along with a tranny cooler. Let me tell you that this procedure sucks even with a lift.
Never remove the plug without the engine running unless you purposefully want to empty the tranny of a large portion of the fluid. And be careful doing a fill with the engine running as that exhaust gets hot quickly.
Old 06-26-2008, 01:50 PM   #20
mickey_7106
CF Senior Member
mickey_7106's Avatar
mickey_7106 is offline   Reply With Quote
Reload this Page DIY Auto Transmission Fluid Replacement?
Tags
2001, auto, c5, change, check, corvette, fill, fluid, fluids, procedure, refill, replace, service, trans, transmission
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
