Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-20-2008, 11:32 PM   #1
dwestsr
CF Senior Member
dwestsr's Avatar
Default service tire pressure monitor system?
I have a 2004 mn6 mag red coupe with 20k miles. It has been sitting for three weeks because of the weather. I fired it up today and got low tire pressure warning on LF and LR tires after I had run down the road a ways. I figured that the cold weather had lowered the pressure a bit and sure enough, after driving for ~ 10 min the low tire warning dissapeared.
Tonight,I drove it again after it has gotten colder (22 F) and I first got low tire warnings on the same wheels but it now is flashing back and forth between LF and RF . Also the heads up is showing "Check Gauges " message. I then stopped and aired up the tires to 30 psig. I still got the same low pressure messages. After driving 20 min, I got the service tire pressure system message.
Do I need to reprogram my sensors? I have the dervice manual but no scan tool. Where do I start?
dwestsr is offline   Reply With Quote
Old 01-21-2008, 12:11 AM   #2
Evil-Twin
CF Senior Member
St. Jude Donor '03-'04
Evil-Twin's Avatar
Take your tire pressure up to 35 psi... the cold ground will lower the intenal temps and you will be fine.. you get a warning at 25 psi... if the tires are warm when you add air you need to check the air pressure when warm.... so that when they sit they will go under the lov pressure limit. so go and put 35 psi in them.
Evil-Twin is offline   Reply With Quote
Old 01-21-2008, 05:16 AM   #3
trussme
CF Senior Member
trussme's Avatar
Default If you need to reset the tire pressure monitors...
....do this:
1) Turn ignition on 2) Press "Reset" button in order to clear any IPC display warning messages 3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank 4) Press and hold the DIC "Reset" button for 3 seconds 5) Press the "Options" button again until TIRE TRAINING message appears 6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming 7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem 8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over) 9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
The Tire Pressure units in the tires have a small radio transmitter in them. They transmit 2 pieces of data ... the tire pressure, and the units unique serial number.
The radio transmissions are picked up by the RFA (Remote Function Actuator) which is a radio reciever that also picks up the transmissions from your key fobs. The data is then sent to the BCM from the RFA, and the BCM has the software that displays/alarms the tire pressure data.
When you move tires around on the car, and then go into TPMS "training" mode, the BCM displays a message to train the LF tire. The magnet you put near the tire stem wakes up the sensor and it transmits its serial number and tire pressure. The BCM then internally stores the information that that particular unit (serial number) is at the LF position. As you go round the car training the system, the BCM is simply "learning" the serial numbers of the sensors, and where they are located.
When the wheels stop turning, after a few minutes, the sensors go to "sleep" to conserve their internal batteries. When the wheels start turning again, the sensors wake up and start transmitting their serial number and pressure again. I believe they transmit several times a minute until the car has been stopped for a number of minutes (like 15 to 20).
trussme is offline   Reply With Quote
Old 01-21-2008, 11:01 AM   #4
dwestsr
CF Senior Member
dwestsr's Avatar
Well, I drove it this morning and everything is working normally. I guess adding air up to 30 PSIG fixed it. I just don't understand why it didn't respond last night. Maybe it just didn't like the cold. It is a "Southern" car after all!
Old 01-21-2008, 12:08 PM   #5
Crewrow
CF Senior Member
Crewrow's Avatar
Quote:
Originally Posted by trussme View Post
....do this:
Question for you: I recently got an error on my 99 vette regarding the rear right tire not reading pressure right. So last night I bought a magnet at a local hardware store, printed out those instructions and went to reset tire. Started with front left, no prob, got the horn, moved over to front right and nothing. Tried again for about 15-20 minutes and everytime I couldn't get past that tire in the sequence. And that's not even the one having problems......
Thoughts?
Crewrow is offline   Reply With Quote
Old 01-21-2008, 01:50 PM   #6
trussme
CF Senior Member
trussme's Avatar
Programming Cancellation
1. The programming mode will be cancelled if any of the following conditions are met: - The program mode is exited through the DIC.
- The ignition is turned to OFF.
- All four sensors have been programmed.
- The TPM system has been in the program mode for longer than 2 minutes and no sensors
have been learned.
2. If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point
Old 01-21-2008, 01:56 PM   #7
Crewrow
CF Senior Member
Crewrow's Avatar
But the problem is the magnet won't reset that tire, it's not a time out issue.
Old 01-21-2008, 05:19 PM   #8
trussme
CF Senior Member
trussme's Avatar
Quote:
Sounds like this TPM's battery is dead or the unit itself needs replacing. Is it giving you a psi readout when you check the R front tire pressure on your DIC? Life of a TPM is 6 to 8 years.
Old 01-21-2008, 05:23 PM   #9
Crewrow
CF Senior Member
Crewrow's Avatar
Yes that's what's weird...The Right Rear tire wasn't giving me a reading and was the tire setting of the DIC alarm. So I thought I'd reset all of them with a magnet to make sure it was really dead. Last night when I tried it I couldn't get past the Right Front tire in the sequence which like I said was weird since it wasn't giving me a problem. Now of course since I only got through the Front Left tire, only that one is giving me a reading. I'm going to try again tonight and hopefully I can do all 4 tires in the sequence.
Old 05-11-2010, 04:21 PM   #10
C5_Gunner
Junior Member
Default Have the same problem on TPM sensor
Used a strong magnet and got the first tire to chirp but not the second one. redid and notice no timeout menu was still up. suggestions?
C5_Gunner is offline   Reply With Quote
Old 06-01-2012, 05:59 PM   #11
rascogil
Junior Member
Default tms
I have a similar problem with my 99, Lf sensor was bad , other 3 worked, replaced lf sensor & discount tire activated, lf, other 3 did not display , now reprograming does not wok even with the tool , tried magnet it no work ethier, any suggestion? GRR
rascogil is offline   Reply With Quote
Old 06-02-2012, 08:59 AM   #12
fevest
CF Senior Member
I tried tried the tool, didn't work. took it to the dealer, what a mistake. Told me I needed a new reciever for the car, not the one in the wheel. Laughed that off. My son blew his subwoofer up. Used the magnet from that. They all programmed fine with that huge magnet. No problems since.
fevest is offline   Reply With Quote
Old 06-02-2012, 09:26 AM   #13
65GGvert
CF Senior Member
65GGvert's Avatar
Send a message via AIM to 65GGvert
I guess that 45 day rule on old posts is more of a suggestion than a rule.
65GGvert is offline   Reply With Quote
Reload this Page service tire pressure monitor system?
Tags
05, 2000, c5, corvette, display, instructions, low, monitor, pressure, reset, system, tire, training, warning, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Another Service Tire Pressure System SphyNxXx C5 General 17 04-23-2005 06:54 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
