water pump ?
water pump ?
If the water pump is going bad on a 03z where would the leak from the pump materialize .You know if it was coming from the weep hole. Would it be left side of the block or right. I have some leakig when the car sits and I dont know how to tell if thats where its coming from.
Once it hits the cradle, no telling where it can hit the floor. It should leak directly under the pulley on the pump if its the bearing (weep hole). Check your hoses too.
Water pump is a cheap and easy fix if you do it yourself if you have to do it. Got a rebuilt one for around $100. Not a big job, except for the removal of the coolant.
I'd say maybe three hours. Its not a hard job, just messy. I use aluminum foil and make a funnel where the two hoses on the side attach to the pump then remove the hoses slowly aiming the fluid into the aluminum foil and into the catch basin. Then I cover the front pulley and composite spring with aluminum foil when I pull the pump to keep the coolant off of the rubber in the pulley and off the spring. Then wash everything down. Installation isn't hard but the pump is heavy and keeping the gasket in place while installing can be a bear. This time I am making studs to slide the gaskets and pump on so the gaskets stay in place.
Having the front of the car in the air helps purge the system when you re-fill too.
I drained the coolant from the thermostat housing. Just loosen the bottom housing bolt and the top a little with a drain pan under it. You should get a nice little stream to drop right in. Takes a little more time to drain but you dont have to get under the car. BTW GM has new metal gaskets for the pump. Good Luck
