What did I do to my motor? :(
Old 10-31-2007, 02:00 PM
vetterlatethannever
vetterlatethannever's Avatar
Default What did I do to my motor? :(
I am afraid I killed it........
Was enjoying the M/T ET streets that a friend gave to me last night when I heard a pop that sounded like a small backfire. Engine died and won't start now. I am (was LOL) running a P1SC with only 3-4 lbs of boost and was on it hard in third gear although it wasn't near redline when this happened.
Engine seems to turn over fine. No oil leaks, no water leaks. No smoke from the exhaust (although I did coast for a couple of miles trying to make it home). Opened the oil filler cap and no smoke from there, oil is clean on the dipstick and at proper levels. It seems like it has lost fire, but I am afraid I leaned out the motor and its shot.
No gauges so I very well could have been lean, thought I'd hold off on them for a while ot save a few bucks May have backfired bigtime.
This morning after charging the battery I checked and it seemed to have good fuel pressure. I am guessing that the pump does not run unless the motor is turning but on startup there is a small amount that squirts out from the cap at the end of the fuel rail.
Tons of codes did pop up. I haven't yet written them down but will check those soon.
Give me the good news
Old 10-31-2007, 02:48 PM
kromberg
kromberg's Avatar
List the codes. That is the first step in determining what went wrong.
Keith
Old 10-31-2007, 03:38 PM
Yellow03Z06
Yellow03Z06's Avatar
The good news is you can now buy a forged 402!!!
Old 10-31-2007, 03:40 PM
M_T_0
M_T_0's Avatar
sorry dude, let me know if I can help out.
More Than Zero
BTW it should still start or try to if you blew a piston (it will just run like cold dog poo)
so don't give up hope.
ps could you have lost a crank or cam sensor?
Old 10-31-2007, 04:47 PM
waupachino
waupachino's Avatar
My bet is that since you heard a pop, it lost the timing chain or jumped time.
Old 10-31-2007, 04:49 PM
ZeroHer0
ZeroHer0's Avatar
That is what i was thinking
Old 10-31-2007, 05:28 PM
vetterlatethannever
Thanks for the info so far guys, off to get codes.
Old 10-31-2007, 05:31 PM
American Hydrocarbon
Guest
Posts: n/a
Keep us posted.
Old 10-31-2007, 05:33 PM
mrm1149
Support Corvetteforum!
mrm1149's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Best of luck Joe!
Old 10-31-2007, 05:50 PM
Umrswimr
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
If the chain's gone, then so is the motor....
Old 10-31-2007, 06:00 PM
PFMC3
PFMC3's Avatar
if the timing chain broke it would spit out the intake.
Go back to basics to trouble shoot.
Air,Fuel,Saprk
Old 10-31-2007, 06:20 PM
02gt350
02gt350's Avatar
Air,Fuel,Saprk
IT WOULD?!
Old 10-31-2007, 06:31 PM
vetterlatethannever
List of codes:
PCM
no codes
TCS
C1295H
BCM -
B2482H C
B2578H
B2583H
B2587H
B2592H
U1096H
SDM
B1000H
B1001H
U1016H
U1040H
U1096H
IPC
no codes
Radio
no comm.
HVAC
U1160H
B0333H C
LDCM
B2282H
B2284H
U1065H
RDCM
B2283H
B2285H
U1064H
SCM
B0851H
RFA
U1255H
U1096H
U1064H
U1016H
C2110H
C2115H
I did kill the battery so I think the door control module codes among some others are a result of that. Previous codes were the B0333HC HVAC and secondary air in the PCM. All others are new because I routinely check the codes as the secondary air pops on the check engine light.
Old 10-31-2007, 06:50 PM
Greg_E
Greg_E's Avatar
No PCM codes. If you had some kind of catastrophic failure, I would think you would set at least one code.
You said all those codes are new but all have H (history after them) except two, which were something to do with outside air temp sensor for HVAC and backup light circuit. I haven't checked all of them but C2110 and C2115 were Tire pressure sensor faults.
Old 10-31-2007, 06:53 PM
AVB
AVB's Avatar
pull your intake and check to see if the backfire didn't put a hole in it.
hope it's nothing major..
Old 10-31-2007, 07:15 PM
vetterlatethannever
Every code minus a couple are battery related I believe. Loss of comm with other computers, turn signals, battery 1,2 circuits. The TPS are out because I am running different rims without sensors.
Hopefully going to start disassembly tomorrow but it will be a slow process.
Keep the ideas coming and I'll keep everyone informed!
-Joe
Old 10-31-2007, 07:19 PM
chriswtx
chriswtx's Avatar
Did you try clearing all the codes then try restarting the car??
To What did I do to my motor? :(
Old 10-31-2007, 07:36 PM
Greg_E
Greg_E's Avatar
With the battery charged, can you clear those codes and see what comes back? As you said, most are battery faults comm errors and other seemingly unrelated codes (although they are all related to the BCM).
From your description of the symptom, the intake manifold sounds like a good place to start looking.
Old 10-31-2007, 08:27 PM
PFMC3
PFMC3's Avatar
Originally Posted by 02gt350
IT WOULD?!
If timing chain broke cam wouldnt turn that would leave valves open at incorrect times.
when the motor cranked the pressure from the intake valve being open at the incorrect time would force air into the intake manifold
Just like a older carb with timing 180deg out
Old 10-31-2007, 08:31 PM
T VETTE
T VETTE's Avatar
Quick Reply: What did I do to my motor? :(
