What did I do to my motor? :(
Old 11-03-2007, 10:34 AM
  #61
corvettebob1
corvettebob1's Avatar
Originally Posted by vetterlatethannever
Any chance of not having other damage (pistons, valves) with a small cam and stock (unmilled, maybe more clearance) heads? Or should I expect the worst? Already planning for it.........
Don't know about the LS1/6 motors but Chevy used to make "free spin engines" just in the case of a broken timing chain or valve float.
Best of luck to you!
Old 11-03-2007, 11:18 AM
  #62
vetterlatethannever
vetterlatethannever's Avatar
Well, popping the valvecovers off was easier than I thought... Now I just need another helping hand to crank over the car.
Old 11-03-2007, 11:41 AM
  #63
chriswtx
chriswtx's Avatar
ECS blower cam is not a "small" cam. Your valves would be hitting pistions if the chain broke. Go buy a fuel pressure tester. You need 58psi of fuel pressure...
Old 11-03-2007, 11:59 AM
  #64
123sugey
Dig
Support Corvetteforum!
123sugey's Avatar
just check where the rocker arms are now ... turn it over ... check to see if any have moved from previous position. That is a simple way to do it by yourself.
Old 11-03-2007, 03:25 PM
  #65
vetterlatethannever
Had my fiance crank the car before she went to work, no movement at all in the valvetrain.....
Old 11-03-2007, 03:26 PM
  #66
vetterlatethannever
This is not good news.
Old 11-03-2007, 03:47 PM
  #67
chriswtx
chriswtx's Avatar
Did you use a new timing chain with the new cam??
Old 11-03-2007, 03:50 PM
  #68
PFMC3
PFMC3's Avatar
Not good
You might as well drain the fluids and get started.
You are going to want to check the pistons and valves for damage.
Old 11-03-2007, 04:55 PM
  #69
FRCTony
FRCTony's Avatar
Originally Posted by PFMC3
Not good
But you could just see how it runs with new chain.
Old 11-03-2007, 05:10 PM
  #70
cyclerage23
cyclerage23's Avatar
Not even worth the time. If the chain broke at high RPM atleast 1 or 2 cylinders will have valve damage. If you dont want to pull the heads off,
atleast pull off all the rockers, pull out all the spark plugs and do a compression test.
Old 11-03-2007, 07:45 PM
  #71
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please take pitures of the damage.
BC
Old 11-06-2007, 07:09 PM
  #72
vetterlatethannever
Car hopefully gets picked up tomorrow, I'll keep you guys posted!
Old 11-06-2007, 08:26 PM
  #73
Greg_E
Greg_E's Avatar
I still don't understand why that didn't set a cam sensor code. Can anyone enlighten me?
Old 11-06-2007, 09:37 PM
  #74
vetterlatethannever
I'll see what I can find out.
Old 11-07-2007, 08:26 AM
  #75
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
when my timing chain went it showed the cam sensor code 1 time only. I cleared it thinking it might just be a faulty sensor which I have seen on another persons car. After I cleared it I never got another cam sensor code. It was not until I got back to the shop that I found out the timing chain was broken.
Old 11-07-2007, 02:10 PM
  #76
M_T_0
M_T_0's Avatar
sorry to hear this, let me know if I can Help.
maybe its not too bad
More Than Zero
Old 11-07-2007, 02:36 PM
  #77
vetterlatethannever
More Than Zero
To What did I do to my motor? :(
Old 11-07-2007, 03:02 PM
  #78
vettenuts
vettenuts's Avatar
If its spinning freely and valves are currently stuck open, I would expect the worst. Sorry to hear this, it really sucks.
So what are the new plans
Old 11-07-2007, 04:10 PM
  #79
vetterlatethannever
I wasn't planning on forging yet but if I must I must I don't want to jump ahead on anything though as I still need to work out a problem with the P1SC head that could possibly be costly but hopefully its just a simple fix.
Keep y'all posted
Old 11-07-2007, 05:45 PM
  #80
chriswtx
chriswtx's Avatar
If you go forged you might as well ditch the P1SC and step up to a D1SC...
Quick Reply: What did I do to my motor? :(
