Winterizing at 10500 miles: Should I change the fuel filter??
I always change all my fluids and clean my air filter before I put her to bed and I was wondering if anyone changes their fuel filter at this interval. GM states to change the fuel filter every 15k but I'm a little overprotective so I was thinking about doing a fuel filter change along with everything else. I add a bottle of Redline fuel system cleaner with every oil change so I'm pretty confident the filter's clean but I wanted a second opinion.
Any thoughts??
Thanks in advance
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Porsche DOT4 Hi-Performance Brake
fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
Any thoughts??
Thanks in advance
2000 NBM M6-Coupe
Re: Winterizing at 10500 miles: Should I change the fuel filter?? (ledfoot)
I think your instincts are correct. I have 24,000 plus on my 2000 with no signs of lowered fuel pressure. The Service Manual indicates you should perform the idle learn procedure after installing a new fuel filter. :)
