Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-23-2007, 07:58 PM   #1
docohm
CF Senior Member
docohm's Avatar
Default How to fix your hazard flasher/turn signal problem
Having trouble with your turn signals? Sometimes they work, sometimes they don't? Mine was doing that too, at first I could mess with the emergency flasher button and the turn signals would work. Then I had to move it more and more. Finally, they quit working all together. So I finally took the time to replace it. I documented the whole method here:
http://www.kd5fx.com/vette.html
This is using the 'easy' method where you can do it through the radio hole.
Save the wave!
Doc
docohm is offline   Reply With Quote
Old 09-24-2007, 04:41 AM   #2
kendo347
CF Senior Member
kendo347's Avatar
Thanks. I will have to save this. I need to fix mine.
kendo347 is offline   Reply With Quote
Old 12-27-2007, 09:41 PM   #3
wwwFLA
CF Senior Member
wwwFLA's Avatar
Default Awesome description, glad it was saved in DIY
I've been using the hazard switch to bring back the turn signals on occasion (yes, I know the switch must be bad and should be replaced,post #24) and yesterday did the same thing. This a.m. , no power. A jump got me going all day but I noticed the flasher was running on restart. I must have hit it again for a turn and not turned it off. Through the day no problems with several restarts. The codes above were displayed. Do you think the battery went down because of the flasher left on?
Btw, I've also recently been getting the three way warning......ABS, Active Handling and Traction Control. You think it's related?
I also posted this on the $3600 electrical post but thought I might get a good respose here! Thanks!!
wwwFLA is offline   Reply With Quote
Old 12-27-2007, 11:05 PM   #4
docohm
CF Senior Member
docohm's Avatar
I'm not sure I understand your problem, you think the flasher was running all night and you didn't notice? Don't you think you'd notice if all four lights were blinking when you got out of the car? OR if you left the turn signal on those go off when you turn off the key. What codes were displayed? you said 'the codes above were displayed' but I don't see a list of any codes. From the ABS, AH & TC warnings you've been getting it sounds like you've got some other problem.
I didn't have any codes or problems at all after changing mine out....
Good luck... DocOhm
Old 12-28-2007, 10:28 AM   #5
wwwFLA
CF Senior Member
wwwFLA's Avatar
Default 2001 coupe ABS, AH & TC warnings have been intermittent
they go off after turning the engine off and then on again. The codes were 1214 and loss of commounication from both sides DTC.
Yes, I think the flasher circuit was on all night but was not working as it too along with the turn signals has been intermitent. Thanks for you input.
Old 12-30-2007, 05:42 PM   #6
wwwFLA
CF Senior Member
wwwFLA's Avatar
Knock on wood, the ABS/TC/ AH warnings have not come back and the turn signals are working every time since the jump. I'm hopeful the flasher circuit is cured.
I do, however, still have the 1214 code current.
Old 02-21-2008, 02:58 PM   #7
jmmy
CF Member
Had similar experience. Bumping the flasher to wake up the signals but flasher didn't blink either unless button was held in. Then later after I'd left, flashers started flashing. Got lucky. Someone called me to say they were blinking.Battery weak, but not quite dead yet. Didn't get any codes.
jmmy is offline   Reply With Quote
Old 02-21-2008, 03:14 PM   #8
nextime
CF Senior Member
nextime's Avatar
delorean6683
What exactly makes these go bad?
nextime is offline   Reply With Quote
Old 02-21-2008, 03:19 PM   #9
docohm
CF Senior Member
docohm's Avatar
Quote:
They are made in ENGLAND! I think that explains it....
Doc
Old 02-22-2008, 08:47 AM   #10
RSchleder
CF Senior Member
RSchleder's Avatar
Default Corvette Enhancements
I recommend you buy a flasher assembly from a supporting vendor, Corvette Enhancements. They sell the small flasher/cable assembly that takes 15 minutes to install and bi-passes the OEM flasher which is prone to go bad again. The assembly sold by Corvette enhancements sells for about $50 and is a terrific product/upgrade.
RSchleder is offline   Reply With Quote
Old 02-22-2008, 11:13 AM   #11
sxeC6
CF Senior Member
St. Jude Donor '06-'07-'09-'10
sxeC6's Avatar
George W. Buffington George Buffington
Quote:
It won't do anything to fix the hazard flashers, but it's a quick fix for the turn signals.
sxeC6 is offline   Reply With Quote
Old 02-22-2008, 11:38 AM   #12
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
I have completely dissected a bad hazard switch and WOW! There very complex inside, There are 5-6 sliding switch contacts, an integrated circuit IC Chip some diodes and a bunch of small springs and some lighting circuits and bulbs.
I believe the contacts get tarnished and or loose some of their tension over time cause of heat and vibration. The contacts did look dirty. There would be NO way to easily repair that switch!
If you still have your old switch, it's a VERY good donor for electrical test pins. The Male pins in the switch base can be removed (busted out of the plastic base) and used to test female pins in female connectors.
In a lot of C5 electrical gremlins the problem is cause buy poor contact in the electrical connectors. If you insert that male pin in a female pin,,,there should be a firm grip on the male pin. A very good example of where the female pins fail the most is in the wheel speed sensor connectors. When mine was bad, the male pin would literally fall out when the female connector was turned up side down.
Without testing the female pin tension,,,,you can end up chasing your tail and replacing a LOT of expensive parts.
BC
Bill Curlee is offline   Reply With Quote
Old 02-22-2008, 11:55 PM   #13
TNX ZORA
CF Senior Member
TNX ZORA's Avatar
<<I believe the contacts get tarnished...>>
My turn signals went dead and resumed working for a while by punching the hazard switch a time or two. I noticed that the more I exercised the hazard switch the longer the signals worked before crapping out. After they died one day about 6 months ago I decided to exercise the hazard switch about a hundred times and see what happened. The signals are still working perfectly as of today.
TNX ZORA is offline   Reply With Quote
Old 02-23-2008, 10:23 AM   #14
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! I use my hazard switch quite a bit. I hate tail gaters! Especially when they tail gate a car that can stop in two times less distance than the one their driving!
It's still the original switch and works very well.
BC
Old 10-18-2008, 04:23 PM   #15
yellow 00
CF Member
yellow 00's Avatar
Excellent post! Should be a sticky !!
Took me about a hour including cleaning all the dash parts before reassembly! One more thing that might help someone out with large hands like myself. Hemostats help get the old one out and positioning the new one,and slide it in place.
yellow 00 is offline   Reply With Quote
Old 07-14-2009, 08:23 PM   #16
docimastic
Junior Member
Default 4-way flasher switch will run battery down
I too have been "working" the 4-way hazard flasher switch for years. Sometimes the blinkers will work, sometimes not. Two comments:
1. Note that if the switch is IN/ON (but the 4-way flashers aren't flashing cuz of the switch problem) and you move the indicator stalk to indicate a turn (and of course the blinker doesn't blink) it will tun OFF that brake light, so if one taps the brakes, it will look like one is indicating a turn in the opposite direction! Keeps the drivers around you confused - not necessarily a good thing.
2. I know from experience <sigh> that the 4-way flasher switch will run battery down if left in the IN/ON position.... WITHOUT the 4-way flashers flashing.
docimastic is offline   Reply With Quote
Old 10-03-2009, 05:37 PM   #17
FL_Dave
CF Senior Member
Default Electrical Cleaner Fix
A friend from this forum stopped by today with the intermittent turn signal problem. A few years back I posted that one could drill a small hole and squirt electrical cleaner inside. We tried this trick and, so far, so good. The whole process takes 10 minutes - much easier than a switch replacement.
This is what the flasher looks like when taken apart.
Click the image to open in full size.
Here are the best drill locations.
Just pop off the flasher button and use a dremel and small drill bit to create a hole large enough to accept the straw from the electrical cleaner. (Practice the hole on a scrap first. The bit is smaller than I first thought.) I only drilled one hole. Put the straw in and hooked up the spray can. A quick squirt, work the flasher, a few more squirts, then work the flasher again.
FL_Dave is offline   Reply With Quote
Old 10-03-2009, 08:00 PM   #18
phils C5 vette
CF Senior Member
St. Jude Donor '12-'13-'14
phils C5 vette's Avatar
It was my car, and this is what I posted on another thread today.
well we tried a little fix on my car today, and it may have worked.
Dave removed the cover to the hazard switch, Drilled a hole the diameter of the little red tube that comes with electrical connection cleaner into the hazard switch. Then sprayed cleaner on the contacts. He cycled the switched 30-50 plus times to rub the contact points, and my flashers worked.
worked the 2 dozen or so times i used the binkers on the way home.
I cycled the flasher switch maybe another 30 times on the way home.
I use my car a couple times a month, so im not sure if it's a true fix, but so far so good. I think it's important to cycle the flasher switch ALOT to clean the contacts. It didnt hurt to try, and it really took 10 minutes. Im not a good gauge because I dont use my car enough, but it seemed to so something.
Thanks dave it was good seeing you again
phils C5 vette is offline   Reply With Quote
Old 04-29-2010, 03:37 PM   #19
Stealth94
Junior Member
Default Suspected cause of Flasher issues
Hello, I have been dealing with this problem for several years and have determined a pattern. Mine acts up when the temps are up, it is quite humid and I use the air conditioning. Never fails in the winter. I can prevent it most of the time by directing the air only to the floor. Inconvenient, but works. I can also fix by directing heat to the upper vent. This seems to dry it out. I think this says there is a problem of humidity in the switch from the air conditioning vent. I am going to try this idea of injecting cleaner, but would like anyone who has actually had the dash apart to comment and let me know if there is the possibility that the vent could have a hole in it or any room to insulate the vent or switch better.
Stealth94 is offline   Reply With Quote
Old 04-29-2010, 03:56 PM   #20
docohm
CF Senior Member
docohm's Avatar
Quote:
Have you replaced the switch? It's not that hard to do or expensive IF you do it yourself and will probably fix this.
DocOhm
Reload this Page How to fix your hazard flasher/turn signal problem
Tags
2001, 2005, c4, c5, corvette, emergency, flasher, flashers, hazard, replace, signal, signals, switch, turn, wont, work, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1992 Emergency Flashers cor92vet C4 Tech/Performance 7 05-07-2014 03:00 PM
Electronic turn signal flasher problem WHIZZHOT C4 Tech/Performance 3 04-03-2014 04:01 PM
Turn Signal Issue kjohn C4 General Discussion 4 10-03-2013 05:30 PM
Turn Signal Issue kjohn C4 Tech/Performance 0 10-03-2013 04:16 PM
Dash turn signal light on solid when headlights on? wjsullivan C3 Tech/Performance 11 06-24-2013 05:58 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
