Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-10-2007, 11:51 AM   #1
Z06-JIM
CF Senior Member
Cruise-In VII Veteran
Z06-JIM's Avatar
Default Removing/Replacing Glove-Box Tips???
Anyone have a good write-up on removing the glove-box?
I'm going to be replacing mine today and was wondering if there are any hidden tricks/tips on doing it?
Also could use info on removing/replacing glove box lock mechanism.
Thanks for any replies in advance...
__________________
__________________
Link to Pics:...... http://jlss.smugmug.com/gallery/1912746_M8rFF
Z06-JIM is offline   Reply With Quote
Old 09-10-2007, 07:57 PM   #2
GUSTO14
CF Senior Member
GUSTO14's Avatar
Jim,
This is really a pretty straight forward operation. The glove box is held in by a bunch or perimeter screws, mostly across the top and one on the door jam side that goes through the right lower wing of the dash pad. The glove box side panel slides under the dash pad here, so pry out a little on the dash pad wing to slip the glove box out. I would also disconnect the connector from the back of the glove box light before you start removing the screws. You should be able to access the connector by reaching inside the glove box while it is open.
There are two 10 mm bolts in the lower hinge area of the glove box also that carry most of weight of the box. You access these two bolts through holes in the bottom of the glove box. Open it up and you will see two plastic plugs that you remove to access the bolts. A 1/4 inch drive with a long extension to reach them works well. They are a bear to get back in though.
I would recommend that you be very careful when removing the 3 or 4 screws across the top of the glove box. The upper frame of the box is quite fragile and little more than a strip of plastic that cracks very easily.
I haven't removed the lock, so I can't help you there.
Good luck... GUSTO
GUSTO14 is offline   Reply With Quote
Old 09-10-2007, 09:14 PM   #3
Patches
CF Senior Member
Support Corvetteforum!
Patches's Avatar
Compartment Replacement - IP
Removal Procedure
Click the image to open in full size.
1.Open the instrument panel (I/P) passenger compartment door.
2.Disconnect the electrical connector from the I/P compartment lamp switch.
3.Remove the trim plugs from the bottom of the compartment door. Reach behind the compartment door and push the plugs out. Use a suitable flat bladed tool on the front side to remove the plugs, if necessary.
4.Remove the lower retaining bolts from the I/P compartment.
5.Remove the side and upper retaining screws from the I/P compartment.
6.Slowly pull the I/P compartment just enough to disconnect the wiring harness connector from the inflatable restraint module switch.
7.Remove the I/P compartment.
Installation Procedure
1.Connect the wiring harness connector to the inflatable restraint I/P module switch connector.
2.Install the I/P compartment.
3.Loosely install the screw which retains the side of the I/P compartment, in order to align the nut on the passenger SIR bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
4.Install the upper retaining screw to the I/P compartment. Tighten
Tighten the retaining screw to 1.9 Nm (17 lb in).
5.Install the lower retaining bolts to the I/P compartment. Tighten
Tighten the retaining bolts to 12 Nm (106 lb in).
6.Align and hold the I/P compartment to the I/P, then install the side retaining screw to the I/P compartment. Tighten
7.Install the trim plugs to the I/P compartment door.
8.Connect the electrical connector to the I/P compartment lamp switch.
9.Close the I/P passenger compartment door.
Patches is offline   Reply With Quote
Old 09-10-2007, 09:25 PM   #4
Patches
CF Senior Member
Patches's Avatar
Lock Cylinder Replacement - Instrument Panel (I/P) Compartment Door
Removal Procedure
1. Open the I/P passenger compartment door.
2. Remove the screws retaining the passenger compartment door handle.
3. Remove the door handle.
4. Insert the key into the door handle lock cylinder.
5. Turn the key 1/4 turn clockwise (LOCK position).
6. Release the lock cylinder retainer. Insert a small diameter tool into the slot on the RH side of the door handle and depress and hold the lock cylinder retainer.
7. Turn the key an additional 1/4 turn clockwise.
8. Pull to remove the lock cylinder.
1. Insert the key into the lock cylinder.
2. Insert the lock cylinder into the passenger compartment door handle. Align the lock cylinder in the same position used for removal, then push to seat fully.
3. Turn the key 1/4 turn counterclockwise to secure the lock cylinder retainer.
4. Turn the key an additional 1/4 turn counterclockwise and remove.
5. Inspect the operation of the lock cylinder. The lock cylinder should only allow a 1/4 turn and should be securely retained in the door handle.
6. Install the door handle to the passenger compartment.
7. Install the passenger compartment door handle retaining screws.
8. Close the passenger compartment door.
Old 09-13-2007, 08:56 PM   #5
Z06-JIM
CF Senior Member
Z06-JIM's Avatar
Thanks guys... .... that helped a lot....
__________________
__________________
Reload this Page Removing/Replacing Glove-Box Tips???
Tags
box, c5, c6, changing, compartment, corvette, cylinder, cylinders, door, glove, hinge, lock, remove, replacement, replacing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
c5 coupes typically leaky? LSUgoTIGER C5 General 34 04-05-2014 12:13 PM
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
