MAF Sensor
99 rewire to 01-04 MAF Sensor
Has anyone taken thier 97-00 MAF harness including the IAT wires and repinned them into the 01-04 maf connector? I need to use the larger MAF for my CAI.
Thanks for the info. Checked the site and found it, $30.00. Was hoping for the cheaper route by rewiring a plug. If all else fails I'll be buying one. Steve
St. Jude Donor '13-'14-'15
Hello---You'll have to re-calibrate you MAF tables when installing the newer style bigger MAF into cars with the earlier version--I tried this mod on my 98 and the fueling was -20% off--dead rich-finally threw codes--would barely idle and ran horribly---I tried adjusting the MAF table--but it is a huge job getting it perfect and after 2-3 days i just gave up and put the stock one back in--with screen---I learned that the 3.5 " MAF is good for 500 HP so really no reason for me to mess with it--only minimal HP gains if you get the table perfect anyway---i would try another way to connect your CAI---JMO---
Can someone send me the link to where on the caspers site the connector is listed?
I looked under thier Corvette page and didn't see it listed.. I could be blind though..
Thanks..
I'm not sure why it's under LT1 products....
