z06 exhaust same as c5
Old 09-12-2007, 09:25 PM
tweakd
tweakd's Avatar
Default z06 exhaust same as c5
Hey Guys,
Friend has a 01 z06 exhaust from the manifolds back....NO TI mufflers. He said it is 3" pipes? Is it the same as mine or did the z06 have larger pipes?
Old 09-12-2007, 10:55 PM
DefenderC5
DefenderC5's Avatar
Only the section from the midpipe back is Ti. The midpipe is still stainless. If none of it is Ti then it's a good bet that it is NOT a Z06 exhaust. Can't comment on the diameter, it is my understanding that it is the same... but that is an assumption.
Old 09-13-2007, 01:21 AM
Last C5
Last C5's Avatar
I've got one of each laying on the garage floor right now and they look like the same diameter to me.
Old 09-13-2007, 01:53 PM
kilrb
kilrb's Avatar
It shouldn't be the same as your 99. I believe all 01's and up (or was it '02?) had the same exhaust manifolds, cats and H-pipe; both Z06 and Coupes. Before that (definitely including 99), the exhaust manifolds were different, and they ended at a different length. Therefore, if you have a 99 and want to go with Z06 exhaust, you have to change out the exhaust manifolds as well as the H-pipe. You can't mix and match. The catback, on the other hand can be switched out independently.
Old 09-13-2007, 03:31 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you have an aftermarket mid section, there NOT 3"!! I believe there 2 1/4" fro the C5 LS1 and LS6.
BC
Old 09-13-2007, 08:57 PM
tweakd
tweakd's Avatar
thanks guys for all of your input. i have a dent in one of my pipes when i botmed out once and thought i could just cahnge it out. Looks like i will leav well enough alone.
To z06 exhaust same as c5
Quick Reply: z06 exhaust same as c5
