1998 corvette conv horn problem
Having a problem with my horn going off. Sometimes it would go off in the early morning hours. Steady sound (not panic mode). I would rap the steering wheel and it would stop until it started again in a few days. Now it will not shut-off unless I pull the fuse. PLEASE HELP IF YOU CAN. Steve
Had the same problem. It was a module in the airbag. Luckily for me, my GMPP covered it. Not a DIY fix unless you are sure about your ability to remove the airbag.
