where do I connect the wire for a tack and shiftlight too?
Old 08-29-2007, 05:54 PM
2000whitec5
2000whitec5's Avatar
Location: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
Default where do I connect the wire for a tack and shiftlight too?
I am hooking up a new tack ans shift light were do i connect the wire to have the rpms read at ?
Old 08-29-2007, 08:20 PM
Patches
Support Corvetteforum!
Patches's Avatar
http://forums.corvetteforum.com/showthread.php?t=619162
Old 08-29-2007, 08:34 PM
Y2Kvert4me
Y2Kvert4me's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I found the wire quickly thanks to the info/pics in that thread...wasn't hard at all.
Also used the tip in post #20 of that thread...use a normal 12v test light...connect the alligator clip to ground, and simply pierce each white wire with the probe...when the tach needle jumps, you found the correct white wire to tap into.
Old 08-30-2007, 06:51 AM
2000whitec5
thank you guys !
To where do I connect the wire for a tack and shiftlight too?
Quick Reply: where do I connect the wire for a tack and shiftlight too?
