Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-13-2007, 08:31 AM   #1
Nick1
CF Senior Member
Nick1's Avatar
Default Parking LIght Removal??
Have moisture in the left front parking light. I guess I will need to remove it and fix a crack somewhere. Any tips on access and removal? Thanks
Nick1 is offline   Reply With Quote
Old 08-13-2007, 11:49 AM   #2
sjc*2
CF Senior Member
sjc*2's Avatar
Default Parking Light Removal
I assume you are referring to the front DRL/turn signals. This is a common problem and I have experienced it myself. The problem is the bulb gets so hot it melts the top of the light housing and allows moisture to get in. Usually the symptom is also blown bulbs.
Some guys have gone through the lower access panel from underneath to get the housing out. I went through the top by taking out the headlamp assembly. There are 3 screws holding the assembly in place to the retraction mechanism. The screws are a little tough to get at (I used metric open ended wrench) but once removed you have full view of the DRL housing below and you do not need to re-align the headlamps. First you have to remove the headlamp surround (3 srews), headlamp covers (4 screws) then the headlamp assy. is in full view.
The DRL assy is held in place by a spring on top, and two hex head screws on the bottom. Easy to reach with a socket wrench and a mirror. My housing on the drivers side was completely burned through the top over where the bulb is so I drilled it out with dremel tool and stuck aluminum sheet in place with high temp sealant. Some guys have just sealed the cracks with sealant. I figured the aluminum would act as a heat sink.
If you search the forum under DRL or blown drl bulbs you can find more info and pics.
sjc*2 is offline   Reply With Quote
Old 08-13-2007, 11:58 AM   #3
Nick1
CF Senior Member
Nick1's Avatar
Thanks, I will probably go in through the bottom unless there is strong sentiment against it. I will also search for more comments. I read about the " burn through" problem before.
Old 08-13-2007, 12:39 PM   #4
Tx Ray-C5
CF Senior Member
Tx Ray-C5's Avatar
I'm going to have to take my passenger DRL/turn signal out as well. I replaced my bulbs about 2 weeks ago and the passneger side one "BLEW UP". So now I have to remove the entire setup just to empty out the broken glass.
So I'll be removing it from the bottom side as well. I don't want to hassle with the "re-alignment the headlamp".
Tx Ray-C5 is offline   Reply With Quote
Old 08-13-2007, 12:50 PM   #5
fixvet
CF Senior Member
Support Corvetteforum!
fixvet's Avatar
Quote:
I've changed mine from the bottom...........per the GM manual!
Easy job!
Good luck...........
fixvet is offline   Reply With Quote
Old 08-13-2007, 03:30 PM   #6
flir_man
Junior Member
Did both of mine from the bottom, routed out the burnt plastic, covered with aluminum flashing and sealed with RTV. Great fix!
flir_man is offline   Reply With Quote
Old 08-13-2007, 05:10 PM   #7
briann510
CF Senior Member
Sometimes my left one works, sometimes it doesn't. Usually when its out a couple roadway bumps or a tap with a long rod through side with headlight up on the white housing and its good to go for another couple weeks. It's one of those things that doesn't bother me enough to actually fix it yet.
briann510 is offline   Reply With Quote
Old 08-13-2007, 09:00 PM   #8
Nick1
CF Senior Member
Nick1's Avatar
Thanks everyone for the comments!
Old 08-14-2007, 01:49 AM   #9
sogysailor
CF Senior Member
sogysailor's Avatar
Default This worked for me
EZ access
I found that if you reach into the brake cooling duct directly under the turn signal and slip/push the cooling duct back off the cowling you can easily reach the bulb. Just slip your hand in , release the bulb assembly, and pull it out the front through the brake cooling duct. Change out the bulb, be sure to check it works before you reinstall, then reverse the procedure to put everything back. I have big hands and I found this was very EZ to do. Hope this helps
sogysailor is offline   Reply With Quote
Old 08-22-2007, 08:29 PM   #10
Nick1
CF Senior Member
Nick1's Avatar
Did the job last night, went in from underneath and it was pretty straightforward (rhino ramps). Had a cracked lens which I sealed up and replaced the both bulbs at the same time. The main bulb socket was kind of burnt though...mmmm
Reload this Page Parking LIght Removal??
Tags
1998, c5, corvette, housing, light, lights, parking, removal, remove, removing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
6 CD changer AUX input Silver Console Removal Pictures XM Radio Arm Rest richbell C6 Corvette General Discussion 11 12-05-2004 07:41 PM
Zaino tips for light scratch removal?? very light only seen under flourescent Ericthewolf C4 Tech/Performance 9 08-27-2002 02:07 PM
I did a really dumb thing today and need help w/ash tray lid removal Arkay C5 Tech 23 10-09-2001 10:41 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
