How fast are you going with a STOCK REAR???
How fast are you going with a stock rear and an A4 Automatic tranny???
Depends on the speed limit, my mood, what gear I'm in and lots of other variables. There are two stock rear ends in an A4. 3:15 and 2:73
If you're asking which rear end you have based on speed, put it in 3rd and drive at a steady 75 mph. Divide your rpm's by 1000 and that's your rear end ratio. (3150 rpm's=3:15's). If your asking top speed, I wouldn't know.
Depends on what type of modifications are done to the engine... Stock rear end could be a 3:15 or 2.73.. Horsepower will determine how fast the car is on a stock rear end
Ok, let me rephrase the question. What I mean is, how fast are you running down the 1/4 mile or 1/8 mile track with a stock rear that has somehow managed to stay together. I dont give a crap what kind of mods you have, I just want to know who has a rear that is staying together under serious horsepower applications. Serious meaning 400+ at least.
Still has two stock rear ends, 2:73 and stock 3:15. I don't track mine, so I'm dropping out of the conversation.
I bet it would live for a little while with slicks and about 400-430rwhp, but after that you'd be pushing it. Luckily, you have the A4, so its less of a strain to the rear than it is in the M6. I bet it would take less than that to break a stock rear with an M6. This is assuming you are taking it to the track each weekend.
I would say if you change the fluid more often than normal and have the above you should be ok. Now, axle seals might not last a long time but they aren't expensive to replace, (if you do the work yourself).
And for the record, I knew exactly what you were talking about in the initial post
LOL, guess i got a little frustrated
St. Jude Donor '13-'14-'15
390 RWHP 3.15 's A4 drag radials 12.49 best ET 113 MPH--- no spinning with the DR's--I've seen '07 C6's snap a shaft with wheel hop and a 6 speed--an A4 is not as violent at the start so I isn't as likely to break
