clutch pedal issue
clutch pedal issue
the other night I got into it pretty good, just to clean the cobwebs out, and when I shifted into second (hard, quick shift) the clutch pedal only lifted up to the point where the clutch itself ingages. it shifted normally through the gears but didn't return to the full out position until I lifted it with my foot. it hasn't done it since, but I haven't romped on it either.
anyone else have this happen? is it associated with a problem or should I not worry about it?
Read Rangers post in the above thread, Clutch fluid being nasty is the best place to start. The replace the fluid at home is easy, I change the fliud once a month during track season.
