Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-12-2007, 02:33 PM   #21
drivinhard
CF Senior Member
Support Corvetteforum!
drivinhard's Avatar
Quote:
Originally Posted by vettenuts View Post
The other option that a few have used is to thread the larger unthreaded section of the crank before the original threads started. Hope this makes sense, but it may be your only alternative at this point.
That's what i was suggesting in my above post (but not sure I made it clear). A 3/4" 16 pitch bolt fits just about perfect. The ID of the snout there is just barely larger than what you'd ideally use (off the top of my head, I believe it's .70" and .685" is what is ideal) but it'll work. You can bore it out a tick and go 1 size bigger if you want as well.
There's also just about as much length there, as there is behind it in the threaded area so you've got a decent length of thread engagement area.
Exhibit A
drivinhard is offline   Reply With Quote
Old 06-12-2007, 03:38 PM   #22
Third Gear
CF Senior Member
Third Gear's Avatar
Send a message via AIM to Third Gear
He started a similar thread on LS1 Tech and said he took the block to a machine shop and they said they should be able to fix it.
Oh in that thread he said the bolt broke about 3 inches into the snout.
Third Gear is offline   Reply With Quote
Old 06-12-2007, 04:01 PM   #23
Corvette Don
CF Senior Member
Corvette Don's Avatar
Oh so the block was already out of the car? Update us Mike!!
__________________
2000 Z51 Coupe - SOLD
I will have another one soon
Corvette Don is offline   Reply With Quote
Old 06-12-2007, 04:36 PM   #24
ParamedicC5
CF Senior Member
ParamedicC5's Avatar
Can someone please post a link or tell me what parts I need to make the install tool. I have an ASP pully I need to install...
ParamedicC5 is offline   Reply With Quote
Old 06-12-2007, 05:04 PM   #25
FRCTony
CF Senior Member
FRCTony's Avatar
Quote:
His last words here were "I'm gonna go dig a pit, shoot myself and fall in".
Sorry, couldn't resist.
FRCTony is offline   Reply With Quote
Old 06-12-2007, 06:58 PM   #26
tiojames
CF Senior Member
tiojames's Avatar
Send a message via MSN to tiojames
Quote:
Read posts no. 3,4,and 5.
__________________
04 a4 Lemans vert-582 RWHP/500 ft. lbs.,228/232,205s,A&A Vortech kit,3500 Yank,3:42s,B&M cooler, wire insulators,long tubes w/jet hot coating, SS Works 3" X pipe and RT 3" hi-flo cats,170 stat,hood seal, catch can.,Z06 sway bars,DRM coilovers,tunnel plate,lowered,VIS carbon fiber extractor hood,ACI spoiler,blackouts,ss screens,ss letters,intake area screen,insulation kit, vert partition. C6 Z06 brakes,SS lines,DRM two piece rotors,front ducts,C6 Z06 rims, 9.5x18w2.85/30x18s,12x18w3.35/30x18s.
tiojames is offline   Reply With Quote
Old 06-12-2007, 07:42 PM   #27
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
McMaster-Carr: M16X2 300mm long is what I used, some washers and the M16X2 nuts. See photo above.
vettenuts is offline   Reply With Quote
Old 06-12-2007, 07:43 PM   #28
vettenuts
CF Senior Member
vettenuts's Avatar
Exhibit A
Bingo, didn't fully understand your post but that is what I meant as well. I don't think he has any option at this point other than this unless he wants to have a machine shop try and salvage the original threads.
Reload this Page PLEASE HELP! Broke a bolt off in the end of my crank!
Tags
balancer, bolt, bolts, brocken, broke, broken, crank, crankshaft, diameter, extract, ls1, ls3, polaris, pulley, snout
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Do I need to change distributor gear? AGVI C3 Tech/Performance 12 05-17-2005 10:21 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
