got 2 codes p0430hc and bo605
check eng come on at stop lite checked codes and got p0430 hc and b0605 put lt,s on in dec how to cure these codes and what they mean and what to change and look for without going to the dealer thanks in advance royski i also did the ti ex mod help what should i do
St. Jude Donor '11-'12-'13-'14-'15
P0430 Catalyst System Low Efficiency Bank 2
Your O2 sensor, wiring or Cat on the Passenger side is acting up… Do you even have Cats on there?
B0605 BCM Internal Memory Malfunction
Is this an H or a C.? Have you replaced any other parts on the car inside or out?
code
i have after market cats from danatech lt,s headers and the code read po430hc dont know what that means when both letters h and c show up after the code i thought its one on the other and the other code was b0605 with no letters after the code is it because its running to rich from the long tube headers and exhaust mod. when i wind it up and let off the gas it really raps could this rapping blow out my cats i dont know but hope someone knows how to cure the problem thanks royski i also did the air box fiip it mod the cats came with the danatech headers and xpipe also and the stock ti exhaust mod i cleared the codes and thet are not displaid know and check eng light is off will it stay off the light come on for a reason or could it of been a glitch i also dis connected the batt for the bo605 code thankyou very much for any help ski
Well anything is possible as far as glitch's go... Did you get a tune after the Header install? Alot of times the COT needs desinsitized or tuned out to eliminate the Cat Overtemp (COT) which is common with Highflow Cats...
I was more concerned about your BCM to be honest... Keep an eye on it and post back in here if they crop back up again... We'll get Mr. Bill Curlee on the job!
