removing decal off rear window
03-23-2007, 06:27 AM
Help Please,
I have a decal on a rear window that was place inside, on the defrost lines, I would like to remove it , put do not want to damage the defrost, afraid if I just pull it, the lines will come off with it.
Any thoughts?:
Thanks !!!
03-23-2007, 07:54 AM
I would use some GOO-GONE, dont be afraid to soak the decal first. That will help it come off and soften the glue.
03-23-2007, 08:09 AM
heat gun to soften the glue works well too. just get it hot enough to soften the glue but not scorch. back window must be glass and i assume yours is.
jim
03-23-2007, 09:38 AM
Heat sounds like a good idea but whatever you do take it S L O W and
E A S Y.
03-23-2007, 01:06 PM
...turn on the defroster to warm the decal and carefully remove...
03-23-2007, 06:21 PM
I'm sure that you'll get it off properly by following the previous advice, If not, grid repair kits are relatively cheap. Good luck.
03-24-2007, 01:46 AM
Location: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Quote:
Originally Posted by
BanditDude
That's very true. As a backup in case of damage the grid lines are silver oxide. To conduct electricity.
back ,
c5 ,
car ,
corvette ,
decal ,
defrost ,
lines ,
rear ,
remove ,
removing ,
soaking ,
window
