G2 Spindle Ducts vs DRM ducts
I am confused. The LG motorsports G2 Spindle Duct kit says it comes with red high temp hoses. So, if you get this do you still need the DRM duct kit as well? They list the DRM kit as an option for another $200.00?
In the end, I want to extend the factory brake ducts and plumb them up to the G2 spindle ducts. Can I do this with just the red hose supplied?
I want to order it today, but no one is answering, so I figured I would ask you guys here.
I only use the DRM ducts. The hose they provide is long enough to run right up to the back of the discs. A ss hose clamp and a couple of ties does the job and saves a lot of $.
Ok so the red hose attaches to the DRM extended ducts. Why can't you just attach it to the stock vent tip?
I ordered the Z06 ducts and the Spindle kit, I saw the other post about how they go together. It sounds like a little bit of a hak job, but I'll give it a shot before I buy the DRM ducts.
Thanks for the help.
The DRM ducts, by themselves, do a good job of dumping the air much, much, closer to the wheels than the Chevy stockers. Coupling them with any of the spindle duct kits helps seal the deal.
You are correct, IMO, of your assessment that it's still a rather crude arrangement but once you've tracked a car a few times with just the stock setup and observed/felt/paid for the impact of the heat you quickly become more tolerant of less than elegant designs so long as they work.
You can't just attach it to the stock vent tips because it's way too far of a run. I'm guessing that maybe you've never really looked real hard at those stock vents on a C5 when you've been under the front of the car. Chevy's design seems to be based upon assuming that the air is intelligent and knows that after just being randomly dumped into the lower front of the car it should instantly (on each side) head towards the brake rotors and rush across and through the vanes. Most of the air I've encountered has not been imbued with such intelligence.
I tried following a Porsche GT2 around the track a few laps and totally glazed the front pads! those big brembos are no comparison to our stockers! I figured out that you cant drive the vette like he drives the porsche. So, now I out tourque them coming out of the corners and on the straights, but they catch back up as they "wait" for me to brake at the next turn. Hopefully, I can brake deeper into the corners with cooler brakes. Thanks.
Former Vendor
1. Fluid
2. ducts
3. pads
4. ss pistons
5. ss lines
6. If these 5 items still don't give you the edge, please call me
Randy
it is like a garden hose. Look at a 3/4" and look at a 5/8". They look near yhe same to most people. Now go get one of each and turn them on. Then fill a barrel or pretend your house is on fire and you will see a huge difference. Area of a circle is very decieving until you figure the area and difference in the flow.
John is 100 percent correct!!! Yes the GM ducts flow more air then before, but not enough to do the job correctly. If you only have 10 bucks to spend on your brakes I suggest not going to the track to out brake Porsches.
1. Fluid
2. ducts
3. pads
4. ss pistons
5. ss lines
Randy
1. Fluid
2. ducts
3. pads
4. ss pistons
5. ss lines
Randy
