Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 02:13 PM   #1
JJ 86
CF Senior Member
JJ 86's Avatar
Default Replacing the Multifunction switch...
Anyone have any tips on replacing this switch? Mine just took a crap and I have no dash lights nor do I have any tailights. Everything else works headlights, cruise, turnsignals, brakelights etc. all except the dash lights and park lights. I've search the archieves and found many to have the same problem and it turned out to be this switch. Any Ideas?
JJ 86 is offline   Reply With Quote
Old 03-09-2007, 02:27 PM   #2
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
Its easy to replace. Remove the upper and lower shroud covers from the steering wheel where the switch is located. The switch will come out from there. Once the covers are off, its easy to see how to do it. Its close in there to the steering wheel itself, but it will clear. Takes all of 20 minutes to do. When you remove the screws from the lower shroud cover, looking up, make sure which holes you are putting the screw driver into.
dgrant3830 is offline   Reply With Quote
Old 03-09-2007, 02:32 PM   #3
JJ 86
CF Senior Member
JJ 86's Avatar
Does it require any special tools?
Old 03-09-2007, 02:37 PM   #4
2000BSME
CF Senior Member
2000BSME's Avatar
Quote:
My advice is to put the twilight sentinel to work, no multi switch needed for light operation!
2000BSME is offline   Reply With Quote
Old 03-09-2007, 02:40 PM   #5
JJ 86
CF Senior Member
JJ 86's Avatar
Not sure if I have that option. What's the twilight feature?
Old 03-09-2007, 02:56 PM   #6
JJ 86
CF Senior Member
JJ 86's Avatar
nevermind. I don't have the twilight feature so that's not an option. Hopefully its not too difficult to replace the switch.
Old 03-09-2007, 03:00 PM   #7
white90conv
CF Senior Member
Quote:
I think the manual says to remove the steering wheel. Is this not necessary? I got the shrouds loose on mine but could not get them off. I also need to replace the multifunction switch but for a different reason.
white90conv is offline   Reply With Quote
Old 03-09-2007, 04:27 PM   #8
JJ 86
CF Senior Member
JJ 86's Avatar
Ttt
Old 03-09-2007, 04:30 PM   #9
dgrant3830
dgrant3830's Avatar
It did not require anything special on my '99. Its been a long time since I replaced it, but it was probably a simply open end wrench plsu the screwdriver to remove the screws for the shroud. I did not have to remove the steering wheel and it was an easy repair.
Old 03-09-2007, 10:49 PM   #10
white90conv
CF Senior Member
I found another thread:
http://forums.corvetteforum.com/show...=multifunction
which has some more detailed instructions. He loosened the knee pad but this may have been to access the connector.
Old 03-09-2007, 11:47 PM   #11
JJ 86
CF Senior Member
JJ 86's Avatar
Thanks for the info guys! I'll be replacing the switch tomorrow. I'll let you know how it goes.
Old 03-10-2007, 12:26 PM   #12
JJ 86
CF Senior Member
JJ 86's Avatar
I can't believe how relatively easy this job was. My dad had the same problem on his 98 and the dealer charged him over $600 including the price of the switch to fix his. I'm glad I was able to fix this one myself. Thanks for all the info.
Old 03-28-2007, 07:59 PM   #13
goodbeer
Junior Member
goodbeer's Avatar
I've got the same problem on my 2k. Sonetimes the rear lights won't come on when headlights or on, but turning off/on a few times get em on. Now i have ALL lights working except for rr turn signals. Flashers, park/brake lights work in the rr but not turn signals. Anyone want to talm me out of installing a new turnsignal switch?. Found on Carquest for $140
dave
goodbeer is offline   Reply With Quote
Old 04-28-2007, 11:47 PM   #14
RoccoC5
CF Senior Member
RoccoC5's Avatar
I have a similar issue, except my lights will come on after 10 minutes or so... JJ, did yours behave like this, and did the switch fix the problem? Thanks!!
RoccoC5 is online now   Reply With Quote
Old 04-29-2007, 12:00 AM   #15
JJ 86
CF Senior Member
JJ 86's Avatar
My lights would not come on at all. Only the headlights and turn signals would work and I didn't have any park,taillights, or dash lights. I replaced the switch and it cured the problem (knock on wood). No problems since.
Old 04-30-2007, 12:21 PM   #16
MB01C5
Junior Member
I am experiencing the some of the same issues mentioned on this thread.
Can some provide a part number for the multifunction switch and where you purchased it? I have found the turn signal arm assembly for around $180.00. In the instructions from above it didn't note replacing the whole arm assembly.
Please advise.
Thanks!
MB01C5 is offline   Reply With Quote
Old 04-30-2007, 03:42 PM   #17
MB01C5
Junior Member
Old 04-30-2007, 04:36 PM   #18
MattB
CF Senior Member
MattB's Avatar
Talk to Gene at GMpartshouse.com, he will help find the right part and get you a great price on it.
MattB is offline   Reply With Quote
Old 05-02-2007, 01:54 AM   #19
RoccoC5
CF Senior Member
RoccoC5's Avatar
I found it for $165 at gmpartshouse.com...I think I remember seeing it cheaper somewhere. I'll look again.
Old 05-02-2007, 10:20 AM   #20
screw991le
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Send a message via MSN to screw991le
GM PART # 26047377
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $190.98
OUR PRICE: $99.31
www.gmpartsdirect.com
screw991le is offline   Reply With Quote
Reload this Page Replacing the Multifunction switch...
Tags
2000, 86, blinkers, c5, corvette, function, knee, multi, multifunction, number, pad, part, remove, replace, replacement, replacing, start, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Problem with blinkers. Please Help!!! DanielW C5 Tech 14 07-26-2005 04:32 PM
[MCV] Dealer for warrenty work Jason Southeast 20 01-01-2005 04:53 PM
Digital Dash is tickin me off Light84vette C4 Tech/Performance 16 03-27-2003 06:42 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
