Flip-up headlights don't flip-up
Old 02-26-2007, 08:00 AM
brufener
1st Gear
brufener's Avatar
Default Flip-up headlights don't flip-up
I have a 1997 Corvette, and the flip-up headlightslights are not flipping up. Both lights are affected. Here are the symptons:
1. When the switch in the car is turned on, all the lights (including headlights) turn on, but the headlights do not flip-up.
2. When the switch in the car is used, no grinding noise or any other noise is heard by the headlights (but all the lights are on).
3. The night-time light sensor doesn't seem to be doing anything. I checked it at dusk, when it usually works, and it would not turn any of the lights on.
Any idea what is broken? Thanks in advance for all the help.
Old 02-26-2007, 09:17 AM
JAY KOCH
JAY KOCH's Avatar
Try this
http://forums.corvetteforum.com/show...ght=HEADLIGHTS
Old 02-27-2007, 11:21 AM
0TheRadioFlyer97
Former Vendor
TheRadioFlyer97's Avatar
St. Jude Donor '08
sounds like your headlight motors aren't getting the signal to flip up.
Old 02-28-2007, 01:04 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
The headlamp control module is the likely suspect. On the '99, its mounted on the right frame rail just behind the right headlamp.
Old 04-24-2007, 01:30 PM
FRC Shopper
FRC Shopper's Avatar
Did you get this issue fixed? I'm having the exact same problem on my '99. Does anyone have the part # and price for the headlamp control module?
To Flip-up headlights don't flip-up
Quick Reply: Flip-up headlights don't flip-up
