clutch pedal issue
Old 04-21-2007, 11:01 AM
sdh58
Cruising
sdh58's Avatar
Default clutch pedal issue
I just replaced my clutch, pressure plate and flywheel; now my clutch pedal releases approx. 1 inch from the floor. The new clutch is a centerforce dual friction with a fidanza aluminum flywheel.
I have bled the clutch hydraulics several times and no luck. The pedal was fine before the clutch swap.
One theory I have is the TO bearing may be binding? I don't know!
Any ideas/suggestions? I have it back on stands and ready to take apart again.
PS 98 vert mn6
Old 04-23-2007, 11:21 PM
C54DAZ
C54DAZ's Avatar
My SpecII came with a 1/4" shim that goes behind the slave cyl to allow the clutch to engage and disengage as soon as you step on the pedal. But its still not enough. Its still to close to the floor for me. Maybe yours needs something similar.
Old 04-24-2007, 08:11 AM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
PS 98 vert mn6
The new set-up has a thicker disc and needs more pedal travel versus the stock unit.
You could install an adjustable master cylinder by Cartek or McClod.
Old 04-24-2007, 01:17 PM
Max@Cartek
Max@Cartek's Avatar
Give us a call, maybe we can give you an idea what can be done.
Max
908.317.4496
To clutch pedal issue
Quick Reply: clutch pedal issue
