Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-08-2001, 01:14 PM   #1
BatMobile
CF Senior Member
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
BatMobile's Avatar
Default Bulb experts? Turn Signal 4157 bulb vs. 3157?
I needed to change my turn signal indicator for the front right.
The bulb I took out was a part #4157. Yellow bulb with a white base (which was burnt)
The parts store replaced it with bulb #3157 and indicated that it was an acceptable replacement. Yellow bulb with a BLACK base.
It appears to be working.
Are there any bulb experts out there that know if there is a MAJOR difference in the bulbs that would warrant me removing this 3157 bulb ASAP before it damages something?
Thanks!
Neill
BatMobile is offline   Reply With Quote
Old 10-08-2001, 03:03 PM   #2
MySea6
CF Senior Member
MySea6's Avatar
Default Re: Bulb experts? Turn Signal 4157 bulb vs. 3157? (BatMobile)
Neill,
I do not know what the 4157 is, but this weekend three of
us changed ours out because we wanted white DRL's. The
original bulbs in all three were amber 27W/7W 3157's. We
replaced with clear 27W/7W 3157's.
You should be fine. :D
Ken
BTW - Those new wheels look good, Fikse's?
[Modified by MySea5, 1:05 PM 10/8/2001]
MySea6 is offline   Reply With Quote
Old 10-08-2001, 04:32 PM   #3
maninblack
CF Senior Member
maninblack's Avatar
i use white 3157, it looks much better now Click the image to open in full size. :cheers:
maninblack is offline   Reply With Quote
Old 10-08-2001, 05:02 PM   #4
BatMobile
CF Senior Member
Tropical Moderator
BatMobile's Avatar
OK...found some info on Sylvania's site...
This is in PDF format...
http://www.sylvania.com/prodinfo/auto/pdfs/s8spec.pdf
The 3157 and 4157 are different only in their longevity. The 4000 series is a new bulb containing Krypton gases and apparently have up to 4 times the longevity of the 3000 equivalents.
Oh well....just means I crawl under the car a few more times a year.
;):D
Neill
Old 10-08-2001, 07:01 PM   #5
MySea6
CF Senior Member
MySea6's Avatar
Ooops, I fibbed to ya Neill. Just got home and looked.
The original bulbs I pulled were Sylvania 4157's. But, the bulbs we
used as a replacment are Sylvania 3157KLL (Krypton-Long Life) and
not on the web site. Go figure. I do know that all are 27/7's so we
should be safe.
I have seen some use the Hyper White 3157's at a higher wattage
with no problems.
Ken
Reload this Page Bulb experts? Turn Signal 4157 bulb vs. 3157?
Tags
27w7w, 3157, 4157, 4157k, bulb, bulbs, change, corvette, krypton, life, long, replace, safe, signal, sylvania, turn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
